Go to Post I know FIRST is all about changing society. But my approach is one person at a time. - Phil 33 [more]
Unread 15-01-2003, 09:29
Geoffrey4283 Geoffrey4283 is offline
Geoffrey4283 is an unknown quantity at this point
Optical sensor wiring with the EDU Robot
I know optical sensor wiring and schematics has been sort of beaten to death, but I still haven't been able to find a satisfactory way for hooking one of them up to the Isaac 16. The EDu Robot's power supply isn't big enough to run them, so the specs say, so we've got two 9 volts powering the things. Only problem is, everyone says we've got to ground it to the RC, but then the power won't run from the batteries. This is my problem. Can anyone help me out?
Unread 15-01-2003, 11:15
Geoff_494 Geoff_494 is offline
#0494 (Martians)
Geoff_494 is an unknown quantity at this point
Send a message via AIM to Geoff_494
Run the power from the batteries to the brown lead on the sensor, then connect the blue lead to the negative terminal on the battery, and also run a lead from the negative terminal of the battery to the ground pin on the Isaac 16 digital input (so you have 2 leads going to the negative terminal of the battery). This is important because the robot controller uses the ground pin to detect whether anything is connected on the input. Finally, attach the white or black lead (only one) to the input pin of the digital input, test these to see which one you want. (I think white is normally-on, black is normally-off). That should allow you to power the sensor externally but still have it operating as a digital switch for the robot.
Unread 15-01-2003, 17:44
W00T!
If that works, I must say, you are the man. Right now though, I must make an exit and proceed to kick myself.
Unread 15-01-2003, 21:03
#0494 (Martians)
If it doesn't, PM me or IM me at proteus2003 on aim and I'll see if I can help ya out.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
Index of team's post about their robot... Ken Leung Robot Showcase 1 20-03-2002 17:10
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
