Go to Post Once you go hex you'll never go back. - sdcantrell56 [more]
Unread 23-01-2003, 19:01
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
Double Solenoids - assembly.
We got our put together, but no matter what i tried they leak a trickle at 60 psi . . . which is not good but we can stand it.
But how do i wire it? Does it need two spikes? Or can i do it on one. I'm tempted to just use our single soloniod to run both cyliders . . ..
please help.
Unread 23-01-2003, 19:35
Andrew Rudolph's Avatar
Andrew Rudolph Andrew Rudolph is offline
Git 'em!
no team (Robot in 3 Days)
Andrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond reputeAndrew Rudolph has a reputation beyond repute
Send a message via AIM to Andrew Rudolph
There is a diagram on page 11 of the robot on how to wire up some diodes to control the double acting solenoid with one spike relay
iR3 Creative Engineering
Robot in 3 Days
FTC 6323 The Pink TeamMentor
FTC 8996 Pink Fluffy BunniesMentor
FRC 233 The Pink Team Mentor
FRC 1902 Exploding Bacon Mentor
Unread 23-01-2003, 19:52
#1067 (SLUH)
oooo, i was looking in the pneumatics manual.
Thank you.
Unread 23-01-2003, 20:20
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
You don't need diodes to do it. Go to here
http://www.innovationfirst.com/FIRST...sersManual.pdf
This shows you how to do it much easier.
Unread 23-01-2003, 23:18
That's how we did it last year (and were planning to do it this year), even though I had never seen that before. It's good to know we weren't totally out in left field.
Unread 23-01-2003, 23:39
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
Last year, we used code to turn on the pump for one second every five seconds in order to keep our tanks charged up.
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
Unread 23-01-2003, 23:55
ngreen ngreen is offline
AKA: Nelson Green
FRC #1108 (Panther Robotics)
ngreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant futurengreen has a brilliant future
If your pneumatic system is leaking you need to check every connection, remember to use your teflon tape. Soapy water works great for checking for leak, at least for the ones you can't hear.
Unread 24-01-2003, 06:49
Adrian Wong Adrian Wong is offline
#0596 (SciClones)
Adrian Wong is an unknown quantity at this point
Send a message via AIM to Adrian Wong
I think he means the leak occured in the solenoid that had to be assembled.
If I recall correctly, the valves were separate from the electronic bits, and two small screws and two rubber "mesh plates" were supplied in a little baggy.
There were no assembly instructions anywhere, but our team just tried putting the mesh between the valve and the electronics portion of the solenoid. With both rubber pieces in, it leaked air at 10 PSI. We took one of them out (the one that doesn't have grooves to mesh) and left the other one in. We have yet to test this new set up yet.
I'm also curious to know if there are any assembly instructions for those solenoids.
Unread 24-01-2003, 22:33
#1067 (SLUH)
The little leakage was with only the grooved rubber peice in.
But then I found a screwdriver that was small enough not to slip out of the little screws and fixed it.
Heh, I don't know how to read electrical diagrams so I tried to do it without diodes (WHY ISN'T IT WORKING?! WHY!!!???)
but then we figured it out.
soons we get diodes our pneumatics will be complete.
This whole 'build a robot' thing is just too much fun.
Unread 06-02-2003, 20:33
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Yah, Adrianfixed his solenoid too
FIRST Double Jeopardy! (8/27) EddieMcD Games/Trivia 2 28-08-2003 21:41
solenoids from last year Antonio Pneumatics 6 29-01-2003 22:59
Rookie Question. double solenoids... archiver 2001 2 24-06-2002 00:57
Solenoids archiver 2001 9 23-06-2002 23:47
Driving constraints in assembly Jan Olligs Inventor 0 25-02-2002 07:11
