Go to Post I want to take a moment to thank every single FIRST mentor on behalf of all the FIRSTers (students) out there, for giving us the best we can get. - Arefin Bari [more]
Unread 26-01-2003, 03:38
Lord Nerdlinger Lord Nerdlinger is offline
Lord Nerdlinger has a little shameless behaviour in the past
slow Drive system
We're a rookie team, and so far we are working on making a tank drive system with just 1 of the cim motors on each side. gear ratio of 1:3 . Is this not gonna be enough? I'm seeing alot of other teams using two motors together, or a transmission.
Thanks,
Nerdlingers
Unread 26-01-2003, 03:53
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
You will be slow, but you should have lots of power.
P.S. dual motor transmissions add weight, and complexity it is a good choice for most rookies to go with a one motor non shifting drivetrain
[edit] I didnt see that you said 1:3, I automatically assumed it was 3:1. Anyways, yeah what Jimmy said
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 26-01-2003, 06:31
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
Cory
Uh, shouldn't a 1:3 gear ratio make the output rpm greater than 12600, assuming 4200rpm at the output shaft of the motor?
3:1, on the other hand, would equate to approximately 1400rpm, still assuming 4200rpm.
Last season, with the Atwoods, we had two gear ratios. The high speed selection was geared at 10:1, and the high torque selection was 100:1. We moved at a nice 12feet/sec, I would estimate, in high gear. It moved like a snail in low gear, but boy was it hard to stop.
<edit>
I'm leaving the post as it was, but I'm just acknowledging that I am dumb, and that I was thinking in terms of rpm, not teeth per gear.
Thanks to M. Krass and Jon Lawton for clearing that all up for me.
</edit>
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 26-01-2003, 15:02
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
don't the cims only produce 2.2 Nm of torque at stall, and you will not reach due to your 40 Amp limit, so you will only have maybe 6 Nm of torque on either side . . . .
I'd say go slower.
Unread 26-01-2003, 15:15
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Actually you have them reversed. A three to one gear ratio would triple the speed of the robot and a one to three gear ratio would increase the torque of the robot by a factor of three. I believe your confusing the speed ratio and the torque ratio which simply enough are inverses of each other.
Unread 26-01-2003, 15:36
Duke 13370's Avatar
Duke 13370 Duke 13370 is offline
C is for cookie...
#0862 (Team Lightning)
Team Role: Webmaster
Duke 13370 will become famous soon enough
Send a message via AIM to Duke 13370
For the most part, there is almost always a team that is slower and/or less powerful than you.
You shouldn't lose any sleep over it
---Lightning Robotics!---
Unread 26-01-2003, 15:48
Eric Bareiss's Avatar
Eric Bareiss Eric Bareiss is offline
It's a Bird
AKA: BoogyShoes
FRC #1492 (Team Caution)
Eric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of lightEric Bareiss is a glorious beacon of light
Send a message via AIM to Eric Bareiss
Lord Nerdlinger, how big are the wheels you are planning on using?
Because the way i am seeing it assuming 4200rpm output, geared 1:3 puts you at 1400rpm on the wheels which is 23.3 rps multiply that by the circumference of your wheels.
If you are using 6 inch wheels that gives you a top speed of 36.65 fps which is way too fast.
I would recomend having a speed of about 10 or 12 fps. Which would mean you would have to gear it 1:10
Unread 26-01-2003, 16:25
We are using the 9" neumatic wheels, with the 1 gear on the motor shaft and one w/ 3x the teeth on the wheel shafts. I thought the cim motors were 1500 rpm? so that would make the wheels only 500 rpm, right?
Unread 26-01-2003, 16:45
#1067 (SLUH)
I think the drill motors in high gear are ~1500 RPMs
I thought the CIMs ran it up to about 5000 or 5500 or so.
Yah, reduce it more, way more.
Unread 26-01-2003, 17:33
It's a Bird
AKA: BoogyShoes
Yes, the CIM motors have a max rpm of about 5500.
Using the CIM motors geared 1:3 with the 9" pnuematic wheels will give you a top speed of 55 fps,
That is way too fast!
I would recommend gearing 1:10 and using the 6" skyway wheels, this would give you a top speed of 11 fps, much more manageable
Unread 26-01-2003, 17:39
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Our drive is using 2 CIM's and we have them at a 10 to 1 "gear" ratio...
We are very fast, and we have torque to back it up...
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 26-01-2003, 17:48
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Whatever ratio you do decide upon, please remember to make sure that it puts out enough torque at 40 amps to move your robot.
--Madison--
...down at the Ozdust!
Unread 26-01-2003, 18:02
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
I'd say go slower.
the breakers are different this year - i think they're all the way up to 120 amps
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 26-01-2003, 22:29
Dick Linn's Avatar
no team (Synergy)
Hey. Very interesting. CIM is being sued by Motion Systems ( a New Jersey Corporation) beacuse CIM is supposedly bringing in cheap Chinese knock-offs of Motion Systems wheel chair actuators. Read all about it at http://www.levinhawes.com/1/pr/Motio...PrelimInj.pdf.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 26-01-2003, 22:45
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
First, the CIMs are 5500rpm, not 4200. http://www2.usfirst.org/2003comp/Specs/Chiaphua.pdf.
Second, the breakers will not let you get 120amps for a single motor. That is limited to 40. The 120 is the total number of amps the entire robot can draw.
Third, you need a MUCH better reduction than 3:1. With 9" wheels, you probably want a wheel speed of approx 250rpm. This can be accomplished very easily be using the gearboxes FIRST provided with the drill motors in low.
Fourth, until you get a few years under your belt and have been to a few competition to see what works on what doesn't, I wouldn't even recommend attempting a two-motor transmission. Along those same lines, when you do go to a regional, assign at least one person to go talk to other teams and see how they did their drivetrains. It should give you some good ideas for next year.
Chassis Material/Construction sanddrag Technical Discussion 51 05-12-2003 12:59
how does crab drive work? Soukup Technical Discussion 13 25-04-2003 11:31
pic: Drive System CD47-Bot Robot Showcase 3 27-02-2003 14:11
Quad- 1/2 track drive system Ben Mitchell Technical Discussion 24 30-01-2002 11:55
