Go to Post Unless your HS students have earned BSEE and BSME degreees already, how can they lead or run an engineering team? - KenWittlief [more]
Unread 28-01-2003, 21:38
mjt902 mjt902 is offline
mjt902 is an unknown quantity at this point
Is 'using a smaller cylinder' really that easy??
Is the amount of force you get from a .75" cylinder proportional or differential when compared to a 1" cylinder??
I'm trying to make sure that, before we install smaller cylinders on our lifting mechanism, that i won't have to play with the voltage and speed of our compressor to get the same push as the 1" cyl.
My belief is that the pressure buildup is differential with respect to the volume of a cylinder, not dirrectly proportional. Therefore assuming i convert the moles of air and that really freaky constant R (8.314LkPa/Kmol) and V = (4/3)pi.75^2, do i differentiate V or the equation:
P = nRT/V
Geez I'm confused. Any help would be great. Thanx!!!
Top Ten Reasons to Procrastinate:
1.
Unread 28-01-2003, 22:14
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
The force of a cylinder is simply A*P, where A is the cross-sectional area of the cylinder and P is the gauge pressure of the system. For example:
.75" bore: (.75/2)^2*pi*60= ~26 pounds
1" bore: (1/2)^2*pi*60= ~47 pounds
Unread 28-01-2003, 22:38
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Furthermore, if you check the Pneumatics Manual on FIRST's website, you'll find helpful charts that list the extended and retracted force of each diameter bore available to us at values between 20 and 60 psi.
--Madison--
...down at the Ozdust!
Unread 28-01-2003, 23:09
Suneet Suneet is offline
Physicist-In-Training
None #0599 (RoboDox)
Suneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to behold
Send a message via ICQ to Suneet Send a message via AIM to Suneet
Because the air is stored at 120psi, while the cylinders get a regulated suppy at up to 60, the input pressure to the cylinders will usually be constant while they're extending, as long as the pressure of the air stored at 120 does not drop below 60. So you really don't need to calculate rates of pressure change as the cylinder extends due to the changing volume, because the pressure won't change. You do need to know, however, how many actuations you can get from the air at 120 before the stored air drops below 120. Calculate the volume of the tanks and cylinders you'll use to store air, and separately the volume of the actuated cylinder. Use the ideal gas law to calculate the moles of air in the tanks at 120psi (8.16atm), and the moles used by the cylinder at 60psi (4.08atm). Then subtract the second molar quantity from the first to show the amount of air that was lost, and re-cacluate the pressure, again with the ideal gas law. All you're interested in is how many actuations it will take for you to fall below 60psi. As far as re-charging with the compressor is concerned, I'd suggesting determining the re-charge time (from 60psi, or whatever) experimentally, because the rate of air output isn't constant.
Unread 29-01-2003, 16:13
Thanx u all. You cleared up a huge headache for me.
1.
Making a series of spaced holes around a cylinder in inventor James114 Inventor 13 21-11-2004 18:44
roadless cylinder doomsdaytank Pneumatics 2 16-01-2003 16:52
MnM EASY Question of the Day Winners! Mike Bonham General Forum 22 03-05-2002 21:21
Metal In Motion Easy Question of the Day Brian Card General Forum 3 28-02-2002 21:33
Stopping a Piston... Dan 550 Technical Discussion 7 02-02-2002 11:36
