Go to Post Insanity is overrated. - MissInformation [more]
Unread 14-02-2003, 13:41
Hendrix Hendrix is offline
#0538 (Dragon Slayers)
Hendrix is an unknown quantity at this point
one stick drive
Hey, i know this has probably been mentioned, but i couldnt find it, so here it goes.
We are using 1 stick drive this year, and the default isnt working to well. When we have the stick in the up left corner it barely moves towards the left instead of going into a circle. When we lift the bot off the ground to look at it, the left is stopped like it is suppost to be. Any ideas out there?
Unread 14-02-2003, 15:32
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
it is probably just coasting - just cause you're not putting power to a motor doesn't mean that it won't move.
what we usually do with our 1 stick control system is to put a small of amount of power to the opposite track in the opposite direction. that usually makes it work fine.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 14-02-2003, 16:15
Skabana159's Avatar
Skabana159 Skabana159 is offline
Robotics and Field Hockey
AKA: Jesse C. Owens
#0159 (Alpine Robotics)
Skabana159 is on a distinguished road
Send a message via AIM to Skabana159
It is true that sending 127 out to your left motor might let it coast. Another problem could be that you have too much traction, and your wheels aren't slipping in the left and right directions. Tank drive depends on the wheels being able to spin perpendicuar to their axis without too much resistance.
"What most people do not understand is that the Buddha, the Godhead, resides just as comfortably in gears and circuits as in hills and trees. To believe otherwise is to dilute the Godhead."
-Robert Pirsig, Zen and the Art of Motorcycle Maintenance
Unread 14-02-2003, 20:53
Ah, thank you much. /wave
1 stick drive to 2 stick drive wayne 05 Programming 18 01-04-2004 16:41
2-wheel versus 4-wheel drive Ben Mitchell Technical Discussion 23 07-11-2003 00:50
Direct drive or Chain? Suneet Technical Discussion 32 27-03-2003 23:00
what's your most important drive train advice? Ken Leung Technical Discussion 42 07-01-2003 09:58
