Go to Post Just put it in the dryer for a few extra cycles. That should shrink it down nice and small. - notmattlythgoe [more]
Unread 23-01-2002, 21:01
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
Speed loss due to internal friction
Does anyone have any general rules they follow when choosing the gear ratios for their drive system? What I am specifically interested in is how teams account for internal friction in the robot. For example, the specs say that the drill motor output shaft is at 300 RPM in low gear. Now, I can gear this to a wheel that will rotate at a speed that results in 6 ft/sec, for example. However, how much slower will it actually move once it's on the ground and has all sorts of frictional forces acting on it? I know this depends a lot on bearings, chain tension, and design, but are there any general approximations teams use when making these determinations?
Thanks
Patrick
Systems Engineer - Kiva Systems, Woburn MA
Alumni, Former Mechanical Team Leader - Cornell University Robocup - 1999, 2000, 2002, 2003 World Champions
Founder - Team 639 - Ithaca High School / Cornell University
Alumni - Team 190 - Mass Academy / WPI
Unread 23-01-2002, 22:12
Come up with a value for the torque requirement (for example the load that your robot presents - Pull 130 pounds of potatoes on a mock up of your wheel system, if necessary).
You can see by the figures for free speed and the geared down speed (multiplied back up to the motor speed input to the gears) how much "friction" the gear box represents.
Then, with the a Speed-Torque curve for the motor in question in front of you, enter on the torque axis, go up to the line, the at the line, move horizontally to the left, and read the speed.
Power, speed, and torque... AGH Gui Cavalcanti Technical Discussion 5 10-11-2002 19:02
Friction, traction, torque - oh my... Gui Cavalcanti Technical Discussion 30 13-08-2002 18:01
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
