Go to Post Thanks Autodesk! - Al Skierkiewicz [more]
Unread 29-01-2002, 10:03
REVving up for a new season
FRC #2848 (All-sparks)
wheel drive
ok so we had this whole thing planned out on how our drive train will work and are now having to start again because of Small Parts. We bought the bead lock wheels from skyway but they came with a key hub and now we arn't sure how to attach them to the shaft and we can't find rod with a matching key. so if anyone has any ideas on how to attach it to the rod or if anyone knows where to buy matching rod for the wheels that would be infinatly helpful. Thanks in advance
Unread 29-01-2002, 10:55
President, VEX Robotics, Inc.
A Few Solutions
Here are a couple of suggestions:
(1) Use a trantorque. They are in small parts, but are considered a fastener and can be bought anywhere. Fenner drives have trantorques of all sizes.
(2) Have a keyway cut into your shaft. Keystock is sold in many sizes and will fit into the keyway you have cut into the shaft.
Depending on the size of your hole in the wheel, I suggest the trantorque. I would suggest a shaft no smaller than 3/8", so the trantorque outside diameter is 3/4" (that is the size the hole in your wheel has to be). Trantorques can be used right over keyways.
-Paul
Unread 29-01-2002, 11:18
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
http://www.engineeringfindings.com/cat21/p384.pdf
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 29-01-2002, 12:12
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
mcmaster has prekeyed shaft
we buy prekeyed shaft from mcmaster from time to time........it comes in all shapes and sizes
1 stick drive to 2 stick drive wayne 05 Programming 18 01-04-2004 16:41
"Automatic Transmission" Madison Technical Discussion 70 24-11-2003 09:03
2-wheel versus 4-wheel drive Ben Mitchell Technical Discussion 23 07-11-2003 00:50
Tank Stearing - 4 wheel drive Joe P Technical Discussion 12 04-03-2003 23:05
