Go to Post Simply. Minimize. Reduce. It's a good engineering rule, and an even better management one. - Tom Line [more]
Unread 12-10-2003, 12:26
Chris's Avatar
Chris Chris is offline
So apparently it hangs......
AKA: Chris Carnevale
FRC #0177
Chris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond reputeChris has a reputation beyond repute
2003 Drills and Chips
Does anyone know where I can purchase 2 2003 Chip motors (Standard output shaft) and 2 2003 Drill motors? I looked this information up on the FIRST website and struck out at both S&B Tool for the Drills and MMH Ventures for the Chips. I Search old Delphi threads and couldn't find this information. Any help would be appreciated.
Chris C.
Team 229
Unread 12-10-2003, 15:01
generalbrando's Avatar
generalbrando generalbrando is offline
Build, Break, Repeat
AKA: Brandon Mensing
FRC #0246 (Overclocked)
generalbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to beholdgeneralbrando is a splendid one to behold
Send a message via AIM to generalbrando
Is that the company in the documents for ordering the drills? I remember ordering replacement drills and gear boxes and it seems like we ordered from Bosch directly, which makes sense since we ordered the bosch gear boxes from the same place. I don't know how easy it will be for you to get them from bosch directly now that the season is over. When I called and told them I needed the drill and gear sets for FIRST it seemed like they had something special set up. Anyway, I hope that helps. Good luck.
Lead Mentor of Team #246, Boston University Academy and Boston University, Overclocked
www.burobotics.org
Unread 12-10-2003, 18:44
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Andy Baker had a post a while back on where to get the drills. Also, I found this place http://www.toolpartsdirect.com/cgi-b...bosch/3360.561
Unread 12-10-2003, 19:02
UlTiMaTeP UlTiMaTeP is offline
UlTiMaTeP will become famous soon enoughUlTiMaTeP will become famous soon enough
Re: 2003 Drills and Chips
Chris C.
Team 229
Because the chips came from a car jack, I dont know if there on the market OEM by themselves... Try calling Atwood directly
Hows my searching? Call 1-800-Green-Dots
drills and chips Ben.V.293 Technical Discussion 1 07-11-2003 13:11
