Go to Post No such thing as asking too much. There is such a thing as asking too fast, but not too much. - EricH [more]
Unread 30-11-2001, 12:46
President, VEX Robotics, Inc.
Giving a Little to Get a Little
Dr. Joe,
Everything you said is true, but if you are willing to give up the constraint of keeping the motor running exactly at a specific desired point, then the planetary setup is viable. I admit that there is a lot of testing and compensating involved, but I have a lot of data so far and am really close to getting it to work as I have predicted. My biggest obstacle is pushing my way through P-basic (I am, afterall, a mechanical guy) to get the control system to do what I want.
Unread 02-12-2001, 12:14
Matt Attallah's Avatar
Matt Attallah Matt Attallah is offline
Now at sub 14's in a 5000lb vehicle
AKA: Maher Attallah
FRC #0005 (Robocards)
Matt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond reputeMatt Attallah has a reputation beyond repute
Send a message via AIM to Matt Attallah Send a message via MSN to Matt Attallah Send a message via Yahoo to Matt Attallah
Team 5 used the speed changers that came with the drill motors. It worked ok, but our main problem was getting that main hit in-between speed and power. On "Low-Gear" we could pull both goals filled up and balance with no problem, but our tank traks didn't have enough friction to get up the ramp. We had no problem turning with them in low gear. When we went in to "High-Gear" our robot couldn't turn it's self, just go straight very, very fast. (Well, we could turn, but mabye at 15 degrees at a time, after that, we poped breakers!) So, this up comming year, if we can get some $$money$$, we will try to design a nice gear ratio for both sides of the equasion...
That rug really tied the room together...
drivetrain mouts and gears Andrew Dahl Technical Discussion 3 22-01-2003 13:21
My team is toying with drivetrain ideas .. . Frank(Aflak) Technical Discussion 12 10-01-2003 21:52
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
What motors power your drivetrain? Khalicl13 Motors 35 03-12-2002 16:33
Computer modeling of drivetrain and devices archiver 2000 1 23-06-2002 23:02
