Go to Post This is a solemn reminder of how fast time goes by with the blink of an eye, that if you don't run to catch up with it, it will catch up with you and sweep you away. - Ken Leung [more]
Unread 06-10-2002, 20:53
Melissa H. Melissa H. is offline
MIA
AKA: Melissa
Melissa H. is on a distinguished road
Arrow PBasic Question
I'm new to programming PBasic...though I know a little of C and C++(very minimal though ) I was wondering, how can I start learning PBasic and/or find out more on this programming language?
Anything would be helpful!
FIRST Robotics Alumni =D
Unread 06-10-2002, 21:27
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
My advice would be to grab the default code from InnovationFIRST's website (http://www.innovationfirst.com) and go through it line-by-line until you understand it.
After that, I'd try playing around with my emulator (http://FIRSTprograms.tripod.com/Programs.htm) and see what comes out. If you ever run into problems, post them here and you'll get an answer in a few hours at the most.
Also, if you feel like a challenge, here is the code we used last year: http://FIRSTprograms.tripod.com/cog2002.txt
Unread 06-10-2002, 21:34
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
what he said. that's what i did, and considering i had about 2 hours to learn it, i did pretty good.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 07-10-2002, 07:12
MIA
AKA: Melissa
Thanks for the help!!! The http://www.innovationfirst.com was probably the most helpful (with the default program and all.... )
Unread 07-10-2002, 15:30
Matt Reiland's Avatar
'The' drive behind the drive
Thumbs up Even more fun!!
Here is some Swerve code broken into processor slots if you get bored.
Hopefully your team can get the edu robot to try out or get your hands on a IFI controller. For right now the emulator is great also.
Thanks for the hard work rbayer!
PBasic is not that hard but living in the hardware limitations is more difficult.
Unread 31-10-2002, 14:19
f22flyboy's Avatar
f22flyboy f22flyboy is offline
Distributor of Mayhem
#0540 (Rhythmic Disturbance)
f22flyboy will become famous soon enoughf22flyboy will become famous soon enough
I get most of it, but I am confused by this line:
if ((gear_shifting=1) and (gear_count=10)) then shift
do you have to press the top button of your joystick 10 times to shift?
I'm still learning this code so if this is a stupid question feel free to flame me.
Godwin Robotics Association- Rhythmic Disturbance
Team 540 Forums
FIRST Look... FIRST Shot... FIRST Kill.
Unread 31-10-2002, 14:45
My best guess for the code is you have to press the top button to shift gears which will stop both drive motors while the shift takes place, they increment a counter for a delay (gear_count) when it increments to 10 the shift takes place (relay lowGear toggles) when gear_count hits 40 it looks like the section gets skipped over
BUt I am not sure where gear_shifting ever gets reset back to zero after the first initialization.?
Unread 31-10-2002, 14:55
f22flyboy's Avatar
How long
Do you have any idea how long it would be? Does is there a preset time for counter-type variables, or does it depend on the rest of your program?
Team 540 Forums
Unread 31-10-2002, 15:00
f22flyboy's Avatar
startShift:
leftDrive=127
rightDrive=127
gear_shifting=1
gear_count=0
also what is this here for?
p1_sw_top_prev=p1_sw_top
I see that it sets p1_sw_top_prev=0 but why not just say that?
Team 540 Forums
Unread 31-10-2002, 15:17
SlamminSammy's Avatar
SlamminSammy SlamminSammy is offline
SlamminSammy is on a distinguished road
Send a message via AIM to SlamminSammy
The gear_count is a delay to prevent damage to the gearbox and I think the p1_sw_top_prev=p1_sw_top resets the input and as for not setting it equal to zero, the button may not have started in the zero (off) position.
Anyway, Rob will be back in an hour and explain everything.
The opinions stated above are not necessarily those expressed by the FIRST Robotics Program, its participating teams, or any other individual or organization.
Unread 31-10-2002, 15:20
startShift:
leftDrive=127
rightDrive=127
gear_shifting=1
gear_count=0
As for time, it will depend on the program length and the number of processor 'slots' you are using. The longer the program scan, the slower the delay will be.
Gear Count =0 will set up a fresh delay since it increments to 40 and stops incrementing until the next time a gear shift is requested. Gear Count would be at 40 coming into that statement
this type of statement is useful for storing the value of the switch on the previous scan and checking the current state against what you had before to see if a change has taken place, kind of a 1-shot since after the current scan they will both agree again
Unread 31-10-2002, 15:27
f22flyboy's Avatar
how long
Can someone on this team tell us about how long the delay is?
Team 540 Forums
Unread 31-10-2002, 16:05
This is from the archives I assume it to be close
close enough for govt work...
Posted by control guy at 1/29/2001 10:29 AM EST
Student on team #250 from HVCC.
In Reply to: Re: PBASIC Loop Speed?
Posted by Lloyd Burns on 1/28/2001 4:38 AM EST:
The program loops are roughly 1/40 sec. Although, the time between loops can vary if you lose signal momentarily. Also, depending on your code, a program loop may take longer some times around than other times. Such as if you had many strings of if statements and you're having the program go here, then here, then here, etc., etc. Hope this helps.
Unread 31-10-2002, 16:46
Ok, I'm back (sort of). Actually, I'm sitting in my CSci class right now, but I don't really feel like listening, so I'm responding here.
The p1_sw_top_prev=p1_sw_top does exactly what Matt said, it stores the state for the next loop. Since almost no one can press and release a button within 1/40th of a second, we need to make sure that it is actually a "new" button press and not just someones finger left on the switch from earlier. This lets us use the top switch as a toggle. I.e. each time you press it, the gear we are in changes.
As for the timing, it ends up being about 1.5-2 seconds from the time you press the button to the time you can drive again. That is for the full 40 loops. The 10 loop part takes approx. 1/4 as long.
If you can understand this type of time-delay, you have a very good grasp on PBASIC as this type of looping isn't overly intuitive.
Anyway, let me know if there are any other sections that are unclear or don't make sense.
--Rob
Unread 31-10-2002, 22:38
Re: how long
Just plug the code into RoboEmu and see for yourself!
PBASIC Syntax Question Raven_Writer Programming 4 20-08-2003 08:07
Question Obtaining Pbasic 2.5 PyroPhin Programming 3 18-01-2003 01:26
pbasic question Mike375 Programming 14 15-01-2003 06:54
pbasic question archiver 2001 5 23-06-2002 23:50
Another PBASIC Question Ian W. Programming 4 31-01-2002 21:36
