Go to Post Honesty and Integrity is the key to success. - team4384 [more]
View Poll Results: With what motors will you power your drivetrain?
Drill motors 25 25.00%
Chalupa motors 20 20.00%
Drill + Fisher Price 6 6.00%
Drill + Chaupa 37 37.00%
Chalupa + Fisher Price 0 0%
Other 12 12.00%
Voters: 100. You may not vote on this poll
Unread 17-10-2002, 10:02
Mr. Ivey's Avatar
Mr. Ivey Mr. Ivey is offline
Mark Ivey
AKA: Mark
Mr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of light
Send a message via AIM to Mr. Ivey
Atwood and Drill, or at least it's what we did last year. This year we are thinking...
~Mr. Ivey
When you tell a student not to do it, you shouldn't do it. Or else you will wind up with a 3/8" drill bit in your finger... Like I did...
Unread 17-10-2002, 10:17
Greg Perkins's Avatar
Greg Perkins Greg Perkins is offline
7 years, allready!!???!?!?!
AKA: Mongo
Greg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond reputeGreg Perkins has a reputation beyond repute
Send a message via AIM to Greg Perkins Send a message via MSN to Greg Perkins Send a message via Yahoo to Greg Perkins
Originally posted by Wetzel
More than one drive train? As in a halftrack type device? Wheels and treads? Or something more exotic? Care to elaborate?
Hey wetzel, alot of teams do this, they have a primary drive system, and then a secondary (powerful) one, Like CHAOS- 131, they have a tanks system and wheeled, they just engage at different times
look at 157, 237, and 131 for examples
Badjokeguy
myResume -2004: PARC Referee; Beantown Staff; Battlecry Referee; Summer Frenzy Head Referee; River Rage Head Referee, 2005: Pittsburgh Regional Referee; PARC Referee
XBOX Live Gamertag = TrixAre4Kidss
Unread 17-10-2002, 16:22
Matt Reiland's Avatar
'The' drive behind the drive
BOSCH & FP!!
We found the Drill and FP to well compliment each other (important on a swerve drivetrain) on our 4 independent drive modules, especially with the more powerful FP motors this year. We also kept the modules identical left to right so all the motors spun the same direction so that the drill timing was no longer an issue. We used the Chips for the boom that needed alot of power since it wasn't counterbalanced, also they are heavy!! Definately the Drills on the drive they are a perfect fit for that.
Unread 17-10-2002, 19:34
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: BOSCH & FP!!
The drill motor has timing. Your kidding. We've been running it in reverse on one side this whole time. Can you elaborate a little more on this.
Unread 18-10-2002, 07:58
Drill motors are usually timed for better performance in the forward direction (for drill bits and inserting screws) so it has a little better performance in the forward direction. You could (depending on your robot design) see a slight curve in the driving of your robot because of this. Search the forum for Drill Motor timing, I know we have had discussions on it in the past and ways to correct it.
Matt
Unread 18-10-2002, 10:31
Okay thanks. I know runing motors with "negative timing" can lead to excessive heat, arcing, current draw, and wear. So, I'll go look fo those threads.
Unread 18-10-2002, 14:22
sidewinder sidewinder is offline
#0066 (Those medeling penquins)
sidewinder is an unknown quantity at this point
true 4 wheel
For the past 2 years our team has created independantly powered 4 wheel drive systems. In 2001 we used 2 drills and 2 fisher price, but we found that the gearboxes (plastic) kept burning teeth (although they could still run in some instances). In 2002 we used the new chipuas with the same drill syatem we had the year before. It took a while to match the chips to our drills but we got it and it worked fairly well. We never had any overheating problems because we hardly ever moved (lol stradegy always wins). We did notice however that the draw from the drills and chipuas was rather taxing on our batery. Because of this we opted for no pneumatics.
To date we have never worked on our 2002 bots drive train, and only a few post competition events have we had to change our our 2001 bot's gearboxes and one fisher price we burned out (the sleeve on the motor came back and covered the eexaust holes in the back and well lets just say the magic smoke came out).
Unread 12-11-2002, 19:13
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
the drill motors have 15% more power and speed in the forward dirrection, than they do in the reverse dirrection, last year (2002) we put both in the same dirrection, so we were able to go 15% faster in forward (the dirrection our tranny was designed to go) than we did in reverse. we also used the atwood in there to give it plenty of power
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 12-11-2002, 21:20
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
Re: BOSCH & FP!!
Hey- I've heard about swerve drivetrains and last year I saw Chief Delphi's bot- man did it ever drive sweet.. I've never heard any logic explaining how it works- could someone explain it to me or link me to a page.. Thanks..
Unread 13-11-2002, 07:06
Re: Re: BOSCH & FP!!
In a 'swerve' drivetrain each of the 4 wheels has the ability to pivot in the vertical axis. So far, Chief delphi (6 I think) holds the record for the most complex setups including the fully independent 4 wheels steer setup in 2001 using traingle tank treads where each of the 4 could pivot independently of each other. For our first attempt at 'swerve' last year we linked all four drive modules to each other so they pivoted together. Then you place a pot on one of them to pick up position. We converted the rectangular coordinates from the joystick to polar to get a vector that we wanted the wheels to point to. When it is all said and done a 4 wheel steer robot is extremely manuverable and can get out of very tight spaces. We took it a step further and made the drive modules easily replaceable or 'modular' an approach everyone should look into doing after we noticed the modules on wildstang 2001 and how they had spares ready to go in just minutes. For more info, I posted our gearboxes in the whitepapers and the full code for the steering on the Codex and various places on this site under the name pegasus.zip
Happy swerving, many teams can help you on this but each of us has a few secrets up our sleves
Unread 13-11-2002, 17:35
not on CD enough...
Re: Re: Re: BOSCH & FP!!
Thanks for explaining- unforunately I don't have any CAD programs at home so I can't access that .dwg file you had on the white papers.. Anyone have a pic I could look at?
Don't worry- I'm not part of the pit crew here and I'm also not spying for anyone.. Just a curious firstaholic here..
P.S.- That's a nice H2 you're in... sighs...
Unread 14-11-2002, 08:12
A good program for any of you at home for free is VoloView from Autodesk it lets you open and zoom in DWG files without having to buy a CAD package. YOu can not make changes but you can view them.
Unread 02-12-2002, 23:26
PMGRACER's Avatar
PMGRACER PMGRACER is offline
AKA: PAUL GIANNOSA
PMGRACER is on a distinguished road
4 Atwoods!!
For 2002, we successfully used 1 Boesch and 1 Atwood geared to a common output. We geared the motors so that each were operating at 75% output. We never had a problem over heating the drills or the Atwoods. Accelleration was over 10 ft/sec when in high gear, and in low, gave us plenty of grunt to push or pull a few of the big dawgs around the block without overloading the motors and tripping the circut breaker. Depending on what tasks we will need to do in 2003, we will be able to tweak the gearing for higher torque or accellaration over 18 ft/sec. Of course I think it would be cool to have the bot do a big wheelstand as it launches out of the hole and throw out the laundry on the big end...but this is not drag racing....?
Racing is an incurable addiction!!
Unread 03-12-2002, 08:58
Dr.Bot
Posts: n/a
Just a thought ---- Did the winners of last year's Nationals have complicated 2 or 3 motor drives, or did they have simpler, more robust 1 motor drives geared appropriately, and driven well?
The 255 robot (2000 national champ) had 4 motors on the entire robot. FP for the 2 wheel drive, a van door to raise the basket/lift the robot, and a seat motor to open and close the baske door. Strategy, driver skill, reliability usually beat complex drive systems.
So stop bad mouthing the FPs - they will work fine for the Rookies.
Unread 03-12-2002, 09:19
I liked the FP's especially last years, they had great power and better cooling. We used them in the drivetrain also.
45 or 75 amp anderson power products connectors to drill motors? Andrew Wyatt Motors 2 20-12-2001 08:00
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
