Go to Post "I'm not going to tell you all that you all are winners. At this point you are smart enough to know whether you are or you aren't." -Woodie Flowers - Barry Bonzack [more]
Go Back   Chief Delphi > Competition > OCCRA
Unread 25-11-2002, 22:47
Mr. Mac Mr. Mac is offline
#0001 (Juggernauts)
Mr. Mac is on a distinguished road
Womens' Tournament Rules Changes
There are only a few rules changes for the Womens' Tournament on December 7th. Remember: the redesign and all of the modifications made to your current OCCRA robot must be done by the female members of your team. Keep in mind also that the balls will be 6 to 6.5" in diameter. The lowest 24" of the goal towers will each have holes drilled into the vertical PVC pipes every 6". Clear plastic tubing (.25" diameter, available in 10' rolls at Home Depot) will be threaded horizontally through the holes to form a sort of basket. This will keep the balls from falling out too easily but will still allow them to be scored from the sides (and removed by opponents!) There will 10 additional balls in play: an extra one in each human player station and 6 more on the field.
Unread 26-11-2002, 14:09
Rabid Robots's Avatar
Rabid Robots Rabid Robots is offline
#0062 (Grobots(?))
Rabid Robots is an unknown quantity at this point
Anyway we can see a picture/drawing of this?
The 9000 series is the most reliable computer ever made. No 9000 computer has ever made a mistake or distorted information. We are all, by any practical definition of the words, foolproof and incapable of error.
Unread 26-11-2002, 22:38
#0001 (Juggernauts)
Picture of the Goal
Here's a picture of the new goal. If you are going to modify your own, use 1/4" clear vinyl tubing (from Home Depot for $.99 per 10' roll) We removed the outer PVC bottom segments since they served no function with the new design but made drilling too difficult) Also note: we haven't threaded the top layer of tubing yet- it will be 24" high for the tournament. The balls do not come out on their own but (as in the regular season) can be easily pushed through or pulled out. The loose ends are being held together with tie wraps.
Unread 27-11-2002, 21:53
Mullen's Avatar
Mullen Mullen is offline
FRC #0573 (Mech Warriors)
Mullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of light
being that our team only has one ball.. i could probobly do the math but im too lazy right now... how many balls would be able to fit in the short tower and count as a multiplier?
Unread 28-11-2002, 12:21
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
i would assume 3. I think the short tower is 20" from base to ring, then 6 + 6 + 6 = 18 and 6.5 + 6.5 + 6.5 = 19.5 Anything else would be more than 1/2 out and thus not a point
Unread 28-11-2002, 18:40
#0062 (Grobots(?))
But the picture shows that they can be packed, and from the looks of it you can get around 7 (maybe 8) in the short tower.
Unread 29-11-2002, 19:54
#0001 (Juggernauts)
A Guess
I think that Rabid Robots made a pretty good guess; although I have not tried it, I'm sure it holds at least 6 and possibly several more. No modifications have been made to the cart since the balls do not fit under the bar as it is. Obviously, you can fit a lot of these little balls in the cart without them becoming unstable.
Unread 01-12-2002, 04:24
#0062 (Grobots(?))
Re: A Guess
For sure, I'm expecting some pretty outrageous scores compaired to the regular occra season
Uniform rules and enforcers? Ben Mitchell General Forum 31 12-01-2005 20:55
Dilemma - Letter of the rules v. spirit of the rules Natchez General Forum 27 03-04-2003 15:37
OCCRA Women's Tournament 2002 Kevin Smith OCCRA 0 07-12-2002 16:06
Time for new rules! archiver 2001 11 24-06-2002 02:01
Women's Competitive Robotics Tournament Mike McIntyre OCCRA 2 19-11-2001 00:51
