Go to Post Bring 'em on, kiddies. You underestimate the power of Amanda Morrison. - Amanda Morrison [more]
  #31   Spotlight this post!
Unread 02-12-2002, 19:36
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
When working with gears always use an odd gear ratio. ie. 40:11 instead of 40:10 This always promotes even wear and tear on the gears.
  #32   Spotlight this post!
Unread 03-12-2002, 12:52
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
Drivetrain
When working with any kind of motor it's always good to keep the magic smoke inside the case. We have always used the Drill Motor for drive and think it is a quite reliable unit when geared properly.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
  #33   Spotlight this post!
Unread 03-12-2002, 16:28
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
After last year's competition we spent part of the summer developing a new drive transmission design for our robot ED. The drive features a 1:4 ratio between low and high gears, 250rpm and 1000rpm peak power output speeds, up to 65 ft-lbs of torqe, uses the Bosch and Chiaphua motors found in the 2002 kit of parts, and an 8-millisecond response time to shift gears. The prinicpal feature is that the design can be constructed with hand tools, a lathe, and a mill. No CNC, wire EDM, castings, or carbon-carbon componsite construction capabilities are required (hopefully putting it within the reach of most teams)! We play-tested Version 1.0 of the drive system at the Maryland State Fair competition at the end of the summer, and refined Version 2.0 during the fall.
Rather than keep it as a secret, we are making the design available to any teams that want it. It is posted in the White Papers Section. Download it, build it, improve on it, or just look at the pretty pictures - it's all up to you. All we ask is that you let us know about any feedback, and if you do improve on the design, please post your improvements so the entire FIRST community may benefit and improve their capabilities. In the mean time, we are off thinking about Version 3.0 for the 2003 season...
-dave
  #34   Spotlight this post!
Unread 03-12-2002, 20:11
FatNick's Avatar
FatNick FatNick is offline
#0180 (SPAM)
FatNick is an unknown quantity at this point
Send a message via AIM to FatNick
Besides agreeing with all of your other comments I would just like to add one thing if your going to have a Good Drive train its not just the Quality of the drive train. Its the quality and know how of who works on it. We all had some part in working on the drive train on fluffy but their were a few special people on our team who know those gear boxes like the back of their hand every, screw, every gear, every sound that those drive trains make they knew them. And in our case Fluffy our robot well it was very strong and robust but at both regional and nationals we had a few problems with the drive train. Those few select people I was referring to well they put their blood sweat and tears into to those drive trains. They rebuilt our drive train in under 3 hours changed treads in 5 min, and as a freshman last year I worked with many of these people and though they don’t brag and probably don’t even think about it but I hope that they realize they are really what brings our team and Robot together under pressure. That in my view is the most important part of any good drive train. And that is the only other thing besides design that really makes a drive train come together.
Fat Nick
  #35   Spotlight this post!
Unread 05-12-2002, 07:58
I was confused by this so I asked an expert...
"If the large tooth number is evenly divisible by the small tooth number, then the same teeth will always contact each other. So if one tooth gets
slightly damaged, it will continuously wear on the same mating teeth and wear out sooner. If the numbers are not evenly divisible, then the damaged tooth will mate with every other tooth after a certain number of revolutions. Thus the wear will be spread out across the entire gear. So, it does not really have to be odd and even - just not evenly divisible. However, in our applications, this is irrelevant because we do not expect the gear mates to last for many years of constant use. A much bigger consideration is to properly design the gears for size and materials based on the loads required to be carried.
Raul"
Is this what the criteria for the odd ratio is meant to achive?
  #36   Spotlight this post!
Unread 05-12-2002, 12:07
Adam Y.'s Avatar
Adam Y.
no team (?????)
Yeah. I guess I should have explained this better. But thats the whole gist it.
  #37   Spotlight this post!
Unread 05-12-2002, 21:27
RobDeCotiis RobDeCotiis is offline
FRC #1660
RobDeCotiis can only hope to improve
Send a message via AIM to RobDeCotiis
The only components that you are allowed to hook up in the pneumatics system are the components they give you. You cannot put anything custom-built in the line under current rules.
ya i know.. custom stuff were: crank shaft, connecting rods, cams. actuators would be controlled by the cams hitting into some limit switches.. not a bad design.. the cam shaft would be rotated by one of those little motors we got last year and depending on how fast u rotate the cam shaft, the bot goes forward or reverse, fast or slow.. wouldnt have been IMPOSSIBLE like it was, had i had a machine shop to use
  #38   Spotlight this post!
Unread 17-12-2002, 03:53
DougHogg DougHogg is offline
Robot-A-Holic
FRC #0980 (The ThunderBots)
DougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud of
Originally posted by Andrew
1. List all possible types of drive systems (rear differential-caster front, rear differential-Ackerman front, tank drive (treads or chain driven tandem wheels), swerve drive, etc.
Andrew, Team 356
Can you define "rear differential", "Ackerman front" and "swerve drive" for us?
FIRST Team 980, The ThunderBots
2002: S. California Rookie All Stars
2004: S. California: Regional Champion,
Championship Event: Galileo 2nd seed,
IRI: Competition Winner, Cal Games: Competition Winner
2005: Arizona: 1st seed
Silicon Valley: Regional Champion (Thanks Teams 254 and 22)
S. California: Regional Runners Up (Thanks Teams 22 and 968)
  #39   Spotlight this post!
Unread 17-12-2002, 08:18
Matt Reiland's Avatar
'The' drive behind the drive
Here is all of the info on Ackerman Steering (That you could ever want)
http://www.pbracing.com/handling/ack...principle.html
Swerve - Is pretty much the same as 4 wheel steering which could be independent, front & back, or all 4 linked to steer together. The main benefit is incredible maneuverability. Think of driving straight toward something then 'swerving' to the side to avoid it, in this case think up to straight sideways
Rear-Differential (in my mind at least) allows each rear wheel to spin at a different rate opposite of a locked rear axle, by changing the speed of the rear wheels the bot can steer
  #40   Spotlight this post!
Unread 17-12-2002, 10:33
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
http://www.pbracing.com/handling/Ack...principle.html
Link not working.
  #41   Spotlight this post!
Unread 17-12-2002, 10:39
Try it now, for some reason the capital A in Ackerman was causing a problem
  #42   Spotlight this post!
Unread 02-01-2003, 14:53
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Check this out. Similar to Anthony Lapp's (team 857?) drive from last year
http://www.howstuffworks.com/gadget122.htm
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
  #43   Spotlight this post!
Unread 07-01-2003, 09:58
Jim Harbison Jim Harbison is offline
#0484 (lron lammas)
Jim Harbison is an unknown quantity at this point
Lightbulb
NEVER use PLASTIC pulleys and 1 in timing belts.We toasted 10 belts and all the pulleys at our regional Sprocket and chain is the only way except the transmission povided this year is a no brainer..............use it Insure you fabricate a plastic cover for it to keep Foreign objects out of the mesh and lube the gear with lube from one of your old drill motors.Its special lube designed for high tooth contact loading............and PLEEZZZZZZZEEEEEEEEEE go here .www.nuts4first.net/library/Koff02drive-sys.ppt
Jim H
White Paper Discuss: Drive Train Basics CD47-Bot Extra Discussion 6 06-09-2012 11:42
pic: 311's Drive Train CD47-Bot Robot Showcase 2 24-02-2003 18:09
Image Discuss: Drive train CD47-Bot Extra Discussion 4 06-02-2003 11:39
Another chapter in the drive train story AdamT Technical Discussion 19 29-09-2002 13:52
Blowing fuses/tuning drive train DougHogg Motors 10 23-06-2002 00:24
