Go to Post that....was more far-fetched than the tennis ball I threw for my dog earlier today... - TeknicllyInsane [more]
Unread 04-01-2003, 17:49
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Are specs available on the new motors/mounts?
I don't have the rulebook with me here so I apologize if this is in an appendix.
The FIRST site does not have the torque/speed specs for the new motors. Are tey available somewhere?
Also, are drawings for the supplied motor mounts available?
Matt B.
Unread 05-01-2003, 02:06
AdamT's Avatar
AdamT AdamT is offline
#0401
AdamT is on a distinguished road
At the current time, no. In fact the appendix is empty and will only be added to by team updates.
~Adam
Unread 06-01-2003, 09:26
President, VEX Robotics, Inc.
Working On It.
I have contacted the motor manufacturer's for the following motors:
1. Drill Motor
2. Atwood Chiaphua
3. F-P motor
4. Window Motor
I suspect that the globe motor is the same as last year (look in Dr. Joes Motor Spreadsheet in the White Papers section).
I also suspect that the only difference in the Atwood is the shaft, but will confirm. The Atwood from last year has the following performance specs:
1. Stall Torque = 2.2 N-m
2. Free Speed = 5500 RPM
3. Stall Amps = 107
4. Free Amps = 2.3
The Atwood Shaft diameter is: ~7.92mm. This is probably an 8mm shaft undersized by 0.05 to 0.10 mm. The keyway is made for a standard 2mm square key (included in kit).
I want to warn you about the F-P motor!!! The specs in the FIRST manual are for lasts year's Johnson Electric Motor, not the ones that I pulled out of the kit. Our F-P motor only had 19 teeth, not 21 and was not the same motor as last year. I have already contacted the appropriate people at the motor manufacturer and should have the info by the end of the day tomorrow.
As soon as I confirm, I will post all specs and drawings that I receive.
drill motor specs Caitlyn691 Motors 34 17-01-2003 13:33
Q&A Discuss: Are specs available on the new motors/mounts? CD47-Bot Extra Discussion 3 15-01-2003 19:39
motor specs? Gary Dillard Motors 0 04-01-2003 17:54
On-board chip spec's archiver 2000 4 23-06-2002 21:55
Motor specs kmcclary Off-Season Events 4 26-10-2001 22:41
