Go to Post Winning just makes your ego smile. - MooreteP [more]
Unread 06-01-2003, 01:22
Promethium492 Promethium492 is offline
#0492 (Titan Robotics)
Promethium492 is an unknown quantity at this point
Stacking Boxes in A pyramid
If you stack the boxes in a pyramid shape, 2 on bottom and one centered on top does it count as a stack of three because it would be taller than two? Or does it not count as a stack?
Unread 06-01-2003, 01:25
Tom Schindler's Avatar
Tom Schindler Tom Schindler is offline
Now an AIR Striker....
FRC #0078
Tom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond reputeTom Schindler has a reputation beyond repute
Send a message via AIM to Tom Schindler
the measurement of the "stack" is based on height, not the number of boxes in the stack.
The situation you discribed would count as either 2 or 3 tall, depending on how the boxes were meshed together - it is more than likely this number would be three.
Tom
Unread 06-01-2003, 02:12
AdamT's Avatar
AdamT AdamT is offline
#0401
AdamT is on a distinguished road
To elaborate on Tom's post, the measurement for the multiplier will only be height, not total bins. Therefore, if you have a pyramid of 3-2-1, then it most likely would be tall enough to be considered a x4 multiplier. This means you will use 6 bins to get a 4x multiplier.
~Adam
Unread 06-01-2003, 07:59
This is really going to require an answer on FIRST's part. If I was judging this event, I would rule that the pyramid is one stack of a particular height. If it is considered to be the multiplier stack than all containers in the stack do not count for individual points.
Unread 06-01-2003, 08:59
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
Are you saying, for example, that if you have a total 15 bins in your scoring zone but they ALL form a pyramid of 5,4,3,2,1 then you get no points because they are all discounted as part of the stack?
That would be like saying that any bins in contact with the tallest stack are part of the stack because they may be keeping the stack from tipping over and therefore are also discounted.
I don';t agree with that judgment. The only fair way to score it is to say that they would deduct the height equivalent bins and count the rest. In this example the score would be 6 x 9 = 54.
You are right we need more clarification on scoring!
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 06-01-2003, 09:12
If removing one bin causes the pyramid to collapse , then yes they should all be discounted. If they are separate stacks in a pyramid shape then no, only the highest stack would be discounted. Again the test, if you remove a bin, even if it is touching other bins, and the pyramid does not fall then those bins are not part of the multiplier stack.
Anyone who has purchased the bins knows by now that a pyramid shape of alternating bins is not all that stable since the construction can not take advantage of the nesting feature of the bin tops and bottoms.
stacking robots at regionals Ryan Albright Regional Competitions 5 16-03-2003 08:19
what do the stacking boxes look like? Stephen P Rules/Strategy 2 23-01-2003 13:12
breaking boxes illumanat'i Rules/Strategy 6 19-01-2003 15:44
Q&A Discuss: Stacking Boxes in A pyramid CD47-Bot Extra Discussion 9 16-01-2003 22:41
stacking boxes nuggetsyl Rules/Strategy 3 07-01-2003 13:39
