Go to Post Honestly, I'd volunteer my team to be on that alliance. It'd be an honor to touch bumpers with those bots. - ttldomination [more]
Unread 06-01-2003, 22:09
Kai Zhao Kai Zhao is offline
#0686 (Bovine Intervention)
Kai Zhao is on a distinguished road
Send a message via AIM to Kai Zhao
Auxilliary Basic Stamp Chip
I know this was kind of discussed last year but I there weren't any threads with what I wanted.
With the "custom electronics," it is possible to buy a Basic Stamp Chip to use for dedicated control use. But how would one transfer information from the Stamp to the IFI Control System (or vice versa, if possible)?
I *hope* that it is possible to move a byte of information from the I/O pins to the Control System's analog in port (using legal parts). If that is not possible, moving information using the digital in ports.
The data that I want to transfer is stuff like sensor readouts that I would like the Stamp to keep track of information, for example, box distance calculated by using two sensors.
-Kai Zhao
Unread 07-01-2003, 13:48
Jack's Avatar
Jack Jack is offline
FIRST Scouting Network
AKA: Andrew Schenk
FRC #0201 (The FEDS)
Jack is a jewel in the roughJack is a jewel in the roughJack is a jewel in the rough
Send a message via AIM to Jack
There might be a way, but i'm not 100% sure. Go ahead as ask someone in programming
Team 201 - 2003 Great Lakes Semifinalists & 2003 Archimedes Division Finalists :|: Webmaster of www.feds201.com -> FBI Scouting
Winner of The 2003 ChiefDelphi Web Award for: User That Started The Most Non Chit Chat Threads
Winner of: 2003 FIRST Ventures with 5451.68 End Points
All about me: http://knehcsa.vze.com
**Check out the New FIRST Scouting Network**
Unread 07-01-2003, 14:55
Eric Reed Eric Reed is offline
I am somebody now!
#0481 (De Anza Robotics Team)
Eric Reed will become famous soon enoughEric Reed will become famous soon enough
Using the analog ports wouldn't be reliable if you want to transmit the exact byte. I think you should be able to use the digital in for this, however.
Unread 07-01-2003, 15:07
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
You can get data in to the RC fairly easily via the digital inputs, but getting data out of the RC would require that your custom box reads either a PWM or eight relays. Unfortunately, as many threads here have concluded, the IFI control system's PWM is not the same as the STAMP PWM.
Any electrical people know if this is possible?
Unread 07-01-2003, 15:48
nwagers nwagers is offline
#0240 (Mach Vee)
nwagers is an unknown quantity at this point
Send a message via AIM to nwagers Send a message via Yahoo to nwagers
where there's a signal, there's a way...
i think if you used the PWM functions on the outside stamp you could fairly accurately output analog data to the RC... I'll add this to my list of things to try. If you get it to work please share the details here on the forums.
Unread 07-01-2003, 18:36
My main goal is to get an approximate value out of the Auxilliary Stamp Chip. Perhaps if one was truely desperate, they could use the tether/debug talk to the Stamp, but that's insane. However, that data I want to send is more "parallel" and I don't want to tie up tons of digital inputs.
-Kai Zhao
Unread 07-01-2003, 19:11
Re: where there's a signal, there's a way...
The RC's PWM is not the same as the Stamp's PWM, so I'm guessing it isn't going to work. Furthermore, the stamp has no "PWM in" type function.
]Originally posted by Kai Zhao
Doing it throught the program port is actually not that insane. This is how RoboCon works, and it really isn't that hard. Plus, the Stamp has native support for RS-232, so you wouldn't even need any addition electronics. Unfortunately, it is not legal to exchange data in any way other than with the digital/analog inputs on the RC. This also rules out the idea of doing it with PWMs.
May I ask what advantage this would have, aside from letting you input a few number of sensors?
Unread 07-01-2003, 20:34
Morgan Jones Morgan Jones is offline
Morgan Jones is an unknown quantity at this point
Re: Re: where there's a signal, there's a way...
This is not quite accurate. The outputs of the custom circuit can only be connected to the digital/analog inputs on the RC. The circuit may receive input from a PWM out.
From rule C29:
Inputs to the circuits may be connected to the following sources:
· Circuit breaker outputs.
· Speed Controller or Relay module outputs.
· PWM or Relay outputs on Robot Controller.
· Switches, Potentiometers, the Yaw Rate Sensor, Optical Sensors, Motors and
other additional electronics allowed in the restricted parts list.
Morgan Jones
Team 578: Fairport High School/Gleason Works
Unread 07-01-2003, 20:51
Eric Eric is offline
#0030 (Fury)
Eric is an unknown quantity at this point
OK, first of all... I'm pretty sure you're not allowed to be connected to the program port during a match.
Second (and yeah, I am thinking about doing something like this), I'm pretty sure it can be done, and easily. Here's how I would do it:
For inputs to the auxiliary Stamp, feed it with either PWM or relay outputs from the RC. If you want to use PWM outputs, just make them operate digitally, ie. give it either 0 or 255. Then just read the digital data from off the pins on the aux Stamp. You could use one output as a clock to send more data.
To output from the Stamp to the RC, I would say just connect the IO pins of the Stamp to the digital input on the RC. You might have problems with using analog inputs, because I'm not sure how they sample and PWM isn't really a variable analog voltage. You could use a clock line here, too.
If you need more pins on the Stamp, you can try the 40 pin model.
Just a thought, still has a lot of stuff to be worked out.
Eric (an electronics freak)
Unread 07-01-2003, 21:21
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
You guys are right on track. I'll throw in some stuff that might help.
1. Remember that each relay output has 2 bits - so to transfer an 8 bit value from one processor to the other you only need 4 relay outputs.
2. If you read the digital inputs while the other processor is changing them, you can read a corrupted byte. You'll need to figure out some way to ensure that the data that came across the digital ins is valid.
3. I think that the PWM outs from the RC never go full DC. Even at 0 or 255 they're still pulsing, I believe. I'll try to remember to check this tomorrow on the scope, unless someone else can confirm this.
4. Finally, if you have any engineers on your team who have some experience with it, I'd highly recommend trying to use some other processor than the stamp. If you get a HC08 or a PIC you'll get a processor that is orders of magnitude faster, cheaper, and not that much more difficult to program.
Doing a microcontroller based custom circuit is a lot of work but it's fun and it's a great learning experience. We had a good time building ours last year and we're well on our way to having a plan for this year's.
Impending BASIC Stamp Editor Beta 2 release Greg Ross Programming 9 19-09-2003 06:05
I Need Help with downloading Basic Stamp Program archiver 1999 2 23-06-2002 21:57
Is anyone using the BASIC Stamp Preprocessor? Greg Ross Programming 4 12-02-2002 12:24
Question about Basic Stamp miketwalker Programming 3 14-01-2002 13:10
Have a question about the Basic Stamp Chip Boards wes16zeus Programming 3 06-12-2001 08:25
