Go to Post Water game. - dlavery [more]
Unread 07-01-2003, 19:21
SiliconKnight's Avatar
SiliconKnight SiliconKnight is offline
#0824 (SWAT Robotics)
SiliconKnight is an unknown quantity at this point
Send a message via ICQ to SiliconKnight Send a message via AIM to SiliconKnight Send a message via Yahoo to SiliconKnight
Yes, but why? The ones that come on the motor are pretty decent, I don't see how someone without good machining skills and a good mill and lathe can make something comparable. (You would need to hold good tolerances on the shafts, good surface finishes, and the flange on the other end ain't no picnic. On top of that, you have to get through the clutch housing, which I don't think anyone on here had been able to do.
The clutch mechanism that causes the clutch to slip out isn't in the shaft. If you look at the last planetary gear ring, it's not firmly attached to anything. There is a wave pattern running along the top, and what happens is some form of spring loaded pins press into the dimples. When the torque exceeds a certain amount, the pins / ball bearings / etc shifts and the planetary ring rotates (thus the tak-tak-tak-tak-tak sound)
-=- Terence
Unread 07-01-2003, 22:50
Antonio Antonio is offline
Antonio is an unknown quantity at this point
well we want to get a very high gear ratio from the motor for our transmission gearbox, well thanks for the advice, we'll try to think of something
Unread 07-01-2003, 23:04
machenti machenti is offline
machenti is an unknown quantity at this point
Send a message via AIM to machenti
The new transmission looks pretty solid minus the shifter. It looks like the clutch could be locked by putting a few welds on the rings that Terence mentioned. The only part I'd worry about is the shifter. It is the only plastic in the transmission. Also if you look carefully there are some teeth inside the black casing.
-Ryan
Q&A Discuss: HOT drill motors CD47-Bot Extra Discussion 1 27-01-2003 13:31
Should FIRST include Bosch Drill Motors in Next Years Kit of Parts mtaman02 Motors 9 05-07-2002 16:32
Complete Drill, Seat, and Window motors for trade archiver 2000 0 23-06-2002 22:16
what about the drill motors? Ken Leung Motors 2 26-06-2001 02:11
