Go to Post I wish my biology class was this exciting. - MissInformation [more]
Unread 09-01-2003, 16:43
Alyssia Alyssia is offline
Alyssia is an unknown quantity at this point
type of material; conveyor belt
1. Is it legal to use stainless steel in building the robot?
2. Is there a "common" conveyor belt that most teams use?
3. What is the maximum pneumatic RAM?
Thank you.
Unread 09-01-2003, 17:13
Aaron Lussier's Avatar
Aaron Lussier Aaron Lussier is offline
Volunteer for hire
Aaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to beholdAaron Lussier is a splendid one to behold
Re: type of material; conveyor belt
Thank you.
1.Yes it is, as long as you have no sharp edges, or any of the touching the ground
2. Use for what? Wheels, Transmissions, Arm belts
3. I belive that you can only use 120psi before the saftey valve activates reliving pressure, not 100% sure on that one
Team 151 Student/Mentor 2001-2004
US Navy 2005 -2009
Volunteer 2010 - ???
Field Reset Extraordinaire
Unread 09-01-2003, 18:46
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
I'm not sure what you mean. The largest pneumatic piston you can order is 12" stroke and 2" bore. The maximum allowed pressure in the pistons is 60psi, and the max pressure allowed in the storage reseviors is 120psi. I suggest reading the pneumatics manual at http://www2.usfirst.org/2003comp/pne...anual_2003.pdf
Zan Hecht
Unread 09-01-2003, 19:22
pauluffel's Avatar
pauluffel pauluffel is offline
AKA: Paul Luffel
FRC #1127 (Lotus Robotics)
pauluffel is a jewel in the roughpauluffel is a jewel in the roughpauluffel is a jewel in the rough
Send a message via AIM to pauluffel
Last year we made a robot with a conveyor belt to convey the balls into the goal. We used a rubber and cloth belt about a foot wide that was extremely ineffective as it was difficult to tension (and thus it kept sliding to one side), it was heavy (we lost about 1lb drilling holes in it), and it didn"t have enough friction (our pulleys couldn"t move it very well and it couldn"t pick up balls well). One type of belt we saw that looked good and I have seen used in places other than robots is lots of thin (about 3/4 inch wide) rubber/latex/something bands. They were like extruded trapezoids and thus they would fit into grooves in pulleys and would drift and since they were slightly elastic they could be tensioned nicely. They were also very high friction (sometimes used in cafeteria coveyors for trays because they grip well even when wet) so they would pull what they were used on and the pulleys would easily move them. I don"t know what these or called or where you can get them because I"ve never used them, but I think these would be the best things to use.
Unread 10-01-2003, 12:19
cybermind cybermind is offline
#1046 (PRISM Robotics)
cybermind is an unknown quantity at this point
Send a message via AIM to cybermind
Clarification of question 2
A clarification on the "common" conveyer belt question: (#2)
We are thinking of using conveyer belting for driving (Like a tank). But since we are a rookie team we are not sure where to get the supplies or even what we need. Specifically what we wanted to know is:
What conveyer belt do you recomend?
What wheel are we supposed to use with the conveyer belt?
How did you attach the conveyer belt to the wheel?
Thank you for your help!
Unread 10-01-2003, 12:25
SuperJake's Avatar
SuperJake SuperJake is offline
No Problem!
AKA: Jake Classic
FRC #0061 (The Shifters)
SuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud ofSuperJake has much to be proud of
Send a message via AIM to SuperJake
The belt we used on Li'l MOE in the 2001 season is a double-sided timing belt, 1 inch thick. It had excelent traction on the carpets and we never had one snap... we didn't have to modify it at all to use it, and it was easy to tighten. However, we did have to make our own wheels to make them lighter and to keep the 'treds' from comming off.
Never send a person to do a robot's job.
Robots excel at Dull, Dirty, and Dangerous jobs.
Unread 10-01-2003, 12:51
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
While I believe this to be correct, and even think I read it somewhere, I can't seem to find it in the rules.
Can you help me out and tell me where in the rules or elsewhere this is stated? Thanks.
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 10-01-2003, 12:55
AdamT's Avatar
AdamT AdamT is offline
#0401
AdamT is on a distinguished road
Re: Clarification of question 2
OK, so you want a tread design. First off, if you have the money I like BrecoFlex....you should have received a catalog from them in your kit. They sell the material and the pullies for it. Otherwise you could make your own tank treads like we did two years ago (look in the bottom right of the picture with me and pink hair). You can also go with something like double sided rubber belting from Gates.
As for the wheels, in previous years teams have used conveyor belt material and attatched them to wheels...like these or these . We got material(we used neopreme) from McMasterCarr and attached it with screws (you could also use rivets). This year this is a little more tricky because FIRST will be stingy about metal on the playingfield...glue seems one of the only options in this respect....
~Adam
Unread 10-01-2003, 13:01
Mark Pierce Mark Pierce is offline
FRC #0085 (B. O. B.)
Mark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant futureMark Pierce has a brilliant future
Re: Re: type of material; conveyor belt
On page 4 of the previously mentioned pneumatics manual:
the description of the components clearly state the pressures used. It looks like we have an initial pressure switch to tell the Robot Controller when to shut off the compressor, and a system (after the air tank) regulator which must be set no higher than 60 lbs. There is another regulator you can use after the system regulator if part of your system needs even lower pressure.
Unread 10-01-2003, 13:06
Don Wright's Avatar
FRC #0469
Thanks!!! I KNEW I read it somewhere, but I kept looking the the robot rules and it only states the 120 psi limit.
Thanks again!
Product Manager
the provided chassis material Andrew Dahl Kit & Additional Hardware 5 09-01-2003 15:26
material and fastener usage archiver 2000 1 24-06-2002 00:08
Illegal material PDonovan Rules/Strategy 13 16-05-2002 16:53
WASH scouting fields Mike Soukup Scouting 0 04-02-2002 02:39
Best material for wheels. Dr.Bot Technical Discussion 0 21-01-2002 23:32
