Go to Post Nothing is perfect - but AM is a phenomenal company! - iambujo [more]
Unread 08-01-2003, 21:59
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
Best source for gears? Smallparts? drivetrain advice wanted!
We need to build custom gearboxes . . and I am put in charge of getting a basic sketch down. I have one using smallparts carbon-steel gears and sprockets, the Atwood/Chiaphuas, and the Bosch drillmotors and transmissions.
the thing is, using the sprokets and gears from small parts, my ratios are off by about .02:1 . .
like, I want one to be 1.3:1, best I can get is 1.28:1
Is this a problem, will my motors burn up if they are out of ration by 1 or 2 percent (ratios for both motors are a bit low, so maybe just <1%)?
Also, whats a reasonable speed/force? My current design gives us 10 m/s and about 350-400 Newtons (200-250 up the ramp)
I have no idea about efficiency either, so I just random-guessed 60%. This is high or low?
Im using Bosch to transmission to one gear-gear connection, then to the sprockets to drive the wheels, and Chip/Atw. to gear-gear connection to sprocket to wheels. Can I hope for higher efficiency? All parts are from smallparts with a total materials tab of ~$215.00, not including the chain or housing materials or axels, just gears and sprockets.
#%#%#%#%, we are really jumping into this. I have never designed a drivetrain in my life . . and our moderator says "Ok, so why don't you sketch out a drivetrain and chassis for us and bring it in thursday or friday. Ok, greeaaat. And Bob, could you sketch out the bulldozer arms?"
I always get the hard part.
"Relationships are alot like those little packages of condiments you get at fast food resturants -- they're these little magical things that can last forever on a shelf, but once you open them up, they go bad really fast. I just don't understand condiments."
-- Jim, from "Lily & Jim" by Don Hertzfeldt
Unread 09-01-2003, 09:15
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
If you look in your MSC catalog, there should be a whole list of gears in all shapes and sizes. You might be able to find an appropriate gear in there.
Jeff Waegelin
Unread 09-01-2003, 09:26
George George is offline
#0060 (Bulldogs)
George is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to behold
Best Source for Gears
Try Sterling Instruments NY
watch the oz, the lbs take care of themselfs
Unread 09-01-2003, 11:38
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
We use Stock Drive Products (www.sdp-si.com). They have a pretty large selection. It's extremely beneficial for us because they're located on Long Island, and we can call in an order and pick it up the same day or the next day.
--Madison--
...down at the Ozdust!
Unread 09-01-2003, 12:18
ChrisH ChrisH is offline
Generally Useless
FRC #0330 (Beach 'Bots)
To answer Frank's original question:
Being a few percent off on your gear ration should not be a big deal and if properly designed and built your gear efficiences should be on the order of 95-97% per stage.
Christopher H Husmann, PE
"Who is John Galt?"
Unread 09-01-2003, 15:16
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Try the "Mechanisms and Components" section of the Metalworking Web Sites Index. Lots of good stuff in there.
-dave
Unread 09-01-2003, 21:44
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
MSC!
Usually, I buy gears from PIC or Stock Drive, but I'm tired of waiting 2-3 or even 6-8 weeks for gears. The perfect gears for our gearbox this year were quoted at a 6-8 week lead time from Stock Drive...
so...
The system was redesigned for MSC gears only and they will be delivered in 3 days. wooohooo!
Yay for MSC! The FIRST discount we got on this purchase was about 8%... not bad.
Andy B.
Unread 09-01-2003, 22:07
157#1Driver's Avatar
157#1Driver 157#1Driver is offline
Pro E King
#0157 (AZTECHS 157)
157#1Driver is an unknown quantity at this point
Send a message via AIM to 157#1Driver
For gears you could look in MSC, but if you want custom gears, first try and see if you can make them in a machine shop. If not, try Boston Gear. Carbon gears do cost a lot of money too if thats what you wanna buy.
157 The Aztechs
Luck of the Irish
157 - 12 years and still going
Unread 09-01-2003, 22:31
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
10 meters per second? 10 feet per second would be much more realistic. I'd say most bot's move somewhere around 5 fps so 10fps would be in the middle of the "really fast group"
Unread 10-01-2003, 07:56
#0060 (Bulldogs)
Hi
Try RUSH GEAR 24HR SHIPPING!
http://www.rushgears.com
Theres always a Catch.... ($$$$$$$$$$$$)
check Thread "Sources"
Unread 10-01-2003, 08:15
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Post
About sources for gears:
There are a lot of online places you where can buy gears/sprockets… Here are some suggestions from different people:
“A few good small components sources:
www.wmberg.com
www.allieddevices.com” - Keithicus
“mcmaster.com and stock drive products (sdp-si.com) are good sources. Also, motion industries is a good source.” -Joe J.
http://www.globalspec.com
You can search across the industry for the part you want. It is particularly useful for gears and sprockets.” -ChrisH
“We found a company called Motion Industries that carried the identical part. Turns out they have about 500 outlets around the country (check their locator at http://www.motionindustries.com/ ).” -dlavery
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 10-01-2003, 17:22
New favorite gear source: Rino Mechanical Components
I just ordered some precision gears from a place called Rino Mechanical Components. The precision gears that usually take 3 weeks or 6-8 weeks from Berg or SDP can be delivered in less than a week from these guys (at least that is what they told me today).
Also, they are reasonably priced.
The only catch is that their minimum order quantity is 10... but they seemed flexible, letting me slide with ordering 8 of one gear.
Rino Mechanical
I warned the salesmen that I would be recommending them as a good supplier... so if you use them, hopefully they will treat you the same.
Looking at their catolog, these guys also sell other mechanical components (couplings, gearboxes, etc.).
Enjoy,
Andy B.
advice on drivetrain ark_1230 Motors 4 14-01-2003 23:12
