Go to Post I know that it's often dangerous to use common sense in a YMTC thread... - Kris Verdeyen [more]
Unread 11-01-2003, 19:07
Joe P Joe P is offline
Joe P will become famous soon enoughJoe P will become famous soon enough
Helical gears that come with new drill motor
The kit comes with those helical gears that have 1/16" wide keyway and the 5/8" shaft with 1/8" wide keyway. I see the key stock for this application. Is this key stock good enough to hold these helical gears in place on the 5/8" shafts, or do I need to use a collar or something else to prevent the gears from sliding axially along the shafts?
Unread 11-01-2003, 23:05
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Good question Joe
I had the same quesiton ... we have these gears installed on the shafts using the stepped key stock, but one or two of them can still easily slide along the axis of the shaft - also without collars the entire shaft can slide within the bearing inner race. I don't believe FIRST provided collars for the 5/8" shaft (unless I missed them), but then how did the FIRST engineers build a "working" robot chassis at the kickoff using only parts in the kit?
Stu Bloom
Mechanical Engineer - Rolls-Royce Corporation
Pike High School RoboDevils - 1018
Unread 11-01-2003, 23:16
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Errrrmmmm..... That oddly shaped key stock is what your talking about right?? That should fit in both the gear and shaft very hard and should stay put.
Unread 12-01-2003, 10:49
Don Wright's Avatar
Don Wright Don Wright is offline
FRC #0469
Don Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond reputeDon Wright has a reputation beyond repute
Send a message via MSN to Don Wright Send a message via Yahoo to Don Wright
We built up the supplied gearbox using just the key stock and when we tried it, the gears did NOT stay in place. Collars with set screws will be required, at least for ours...
Donald F. Wright Jr.
Product Manager
AVL Instrumentation & Test Systems, Inc.
Unread 12-01-2003, 11:09
jrgrim12 jrgrim12 is offline
Let's have fun!
#1022 (ArcherGEeks)
jrgrim12 will become famous soon enough
Send a message via AIM to jrgrim12
There are retaining rings provided in the kit. They look like a washer with teeth. They slide on one way but don't slide (easily) the other. I would suggest making spacer out of the aluminium tubing they sent you to space the gears off of the bearings inner race. This is what it looked like first did. They don't show it in the expanded view but if you took pictures you can see it on the robots from first.
http://www.archergeeks1022.org/photo...off/index.html
Also don't forget to have clearance for the inner race of the bearing that goes up against the aluminium channel. I hope that helps.
James Grim
www.youthbotin.org
www.ztspeedandfab.com
Has any one stuck a drill motor in the FP trans? Lotownvw Motors 15 21-04-2003 23:57
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
A new record for breaking a drill motor ZacharyD Technical Discussion 23 16-01-2003 16:58
Drill Motor and FP Motor Shaft Diameters Andy Baker Motors 4 11-06-2001 20:12
