Go to Post At least try to make sure other teams are aware of you. Don't be obnoxious, but don't be a wall flower either. - Joe Johnson [more]
Unread 14-01-2003, 16:58
ark_1230's Avatar
ark_1230 ark_1230 is offline
What the Random?
AKA: Andrew
FRC #3138 (Dayton Innovators)
ark_1230 is an unknown quantity at this point
Question advice on drivetrain
Using just two motors, would it be better to chain drive 4 wheels , or direct drive two wheels with two free spinning wheels (casters, 6" skyway, etc.) ?
Our team was originally planning to use 4 CIM motors (they shipped us four) until we read the rule mentioning "using motors in quantities provided" (Update #2)
Really Really need help as we are falling behind!!!
Andrew Kraemer
Team 979
Dayton Dominators
Unread 14-01-2003, 17:03
Matt Reiland's Avatar
'The' drive behind the drive
I would 'Definately' drive all four wheels this year as traction and pushing force will be big players. Going up/down the ramp with casters will be a real hassle. You may want to drive two wheels and have the other set driven off of them
Unread 14-01-2003, 17:11
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Re: advice on drivetrain
You aren't that behind yet.
If you do power all four wheels there are a few things to consider first. Primarily, how wide is your wheelbase? The longer the wheelbase, the harder it is to turn. This also occurs when each wheel in the skid steer has enough traction that it doesn't want to turn because of all the scrubbing. You may want to look into using omniwheels for one of the wheel sets. Do a search on Chiefdelphi or in any search engine to find different styles. Note: if omni wheels are used, you pivot will move back to the center of the non omni wheel set.
Unread 14-01-2003, 23:02
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
1) Your not behind
2) Do 4 wheel drive
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 14-01-2003, 23:12
Moshingkow Moshingkow is offline
Moshingkow is an unknown quantity at this point
4 wheel drive is not necessarily a make or break part of the game this year. at the NYC kickoff, we had a section of the ramp build for us to see. We had a little trouble with our old drive systems in terms of getting up the ramp, but they were not in any way hindered by the two wheel drive system. if anything, i think that 4 wheel drive this year, unless properly done, has the ability to break a team. imagine going up a ramp at an angle, and not being able to turn because of the side friction on the wheels (it happend to us last year)
Rookie advice for the Championship Event Carolyn Duncan Championship Event 2 07-04-2003 17:57
Best source for gears? Smallparts? drivetrain advice wanted! Frank(Aflak) Technical Discussion 11 10-01-2003 17:22
advice on starting a team.. archiver 2001 1 24-06-2002 03:20
WARNING...Dr. Joe's advice on the drill shaft is incomplete! archiver 2000 5 23-06-2002 22:31
Regionals start in one week - final advice or tips Mark Pierce General Forum 2 02-03-2002 18:49
