Go to Post The 3 probably stands for the number of years this season will take off your life - JohnSchneider [more]
Unread 17-01-2003, 12:02
n[ate]vw's Avatar
n[ate]vw n[ate]vw is offline
#0933 (Adler Attack)
n[ate]vw is an unknown quantity at this point
Send a message via AIM to n[ate]vw
Quick release battery connector and 120 amps
Last year we were given a 60 amp circuit breaker with quick release battery connectors also rated at 60 amps. This year we were given a 120 amp circuit breaker -- and motors to match -- with the same 60 amp battery connectors. Will these connectors be able to withstand the current? Does First really intend for us to use these battery connectors outside of their specifications, or should we use two on each battery?
Adler Attack #933 -- Trigos
Unread 17-01-2003, 13:04
Jason Rudolph Jason Rudolph is offline
Alumni of 168
Jason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud of
Send a message via AIM to Jason Rudolph
Even though the connectors might be rated at 60 amps, they will probably get you through the competition without problems. The rating on the connector is meant for long life, and the amount of time in which you actually have current flowing through them is drastically less than what they are designed for. Where I work, we are often forced to use connectors which are severly underrrated (putting 40+ amps through a 15 amp connector) and they will eventually burn up, but it takes a surprisingly long amount of time for them to burn out (maybe 100+ hours of usage). I would not worry about the connectors.
Unread 17-01-2003, 15:49
The battery connectors supplied by first should work for most teams with a few caveats...
1. Robots designed such that high currents are provided by the battery most of the time should look to using a different battery connector. (i.e. teams who end up discharging their battery in just one match)
2. If you use the provided connectors, please use a clamp (ty wrap, velcro, etc.) to hold the connector together. They are easily jarred apart.
3. We use Power Pole connector's for battery.
Unread 18-01-2003, 17:17
n[ate]vw's Avatar
So it is safe to assume that, even though the Quick-Disconnect power connectors are not *rated* for 120A, they are legal (and required?) for use in competition?
Unread 18-01-2003, 18:25
Of course they are legal, they are provided in your kit for that purpose.
Unread 18-01-2003, 19:27
Rob Colatutto's Avatar
Rob Colatutto Rob Colatutto is offline
Roboticsrob
FTC #10092 (Green.Griffins;)
Rob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to beholdRob Colatutto is a splendid one to behold
where can you get the other connectors to use for the battery from
Follow me on twitter @roboticsrob and my FTC team @griffins10092
Unread 18-01-2003, 23:41
Anderson power makes some nice 120 amp connectors (and higher ones). The 50 amp connectors in the kit are actually the bottom of thier product line.
