Go to Post Don't trust everything you read on Chief Delphi. - Peter Matteson [more]
Unread 22-01-2003, 19:11
JT Academy JT Academy is offline
#0851 (Froggers)
JT Academy is an unknown quantity at this point
Shifting Device
Has anybody out there come up with a good idea on how to shift the drill motors from high speed to low speed?
Unread 22-01-2003, 19:52
Umm Errr...
how about a leadscrew mechanism and some kind of collar around the shifter.
1139 Alumni
Unread 22-01-2003, 20:40
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Or howabout a servo?
Check the whitepapers.
Matt D's Avatar
Matt D Matt D is offline
college time!
FRC #0254 (Cheesy Poofs)
Matt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to allMatt D is a name known to all
shifter
We are using servos to shift the drill motors. We used a similar system in 2001. We have found that this works quite well and reliably
-Matt Durstenfeld
Unread 22-01-2003, 22:17
BBFIRSTCHICK's Avatar
BBFIRSTCHICK BBFIRSTCHICK is offline
Someone find me a FIRST team
AKA: Adriana
#1077 (was: All Stars)
BBFIRSTCHICK is on a distinguished road
Send a message via AIM to BBFIRSTCHICK
Last year we used a servo, and we are looking to using the same thing. (we have a 2 speed transmission) the only problem was the servos are not the most reliable thing....so we are trying to work the bugs out of it!
Team 59 "Ramtech": 2000-2002
Nationals 2001: Galileo Division Champions, National Semi-Finalist
Team 1077 "All Stars": 2002-????
Semi-Finalist, Peachtree Regional 2003 (507 and 356 Rock!)
Unread 22-01-2003, 22:20
Specialagentjim's Avatar
Specialagentjim Specialagentjim is offline
"I am a Meat Popsicle"
AKA: Jim Martz
None #0108 (SigmaC@T)
Specialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to behold
Send a message via AIM to Specialagentjim
Want..to post..but..team kill... if I do....
Sucks being an animator..
Curie Division 2005 Champions (175, 33, 108)
UCF 2005 Website Award
Midwest 2005 Delphi's Driving Tomorrow's Technology
2004 UCF QuarterFinalists (1065, 86, 108)
UCF 2003 Regional Champs/Entrepreneurship Award
Midwest Regional 2003 Leadership In Controls/Website award
Nationals 2003 Quarter Finalists
Robot Rodeo 2003 Champions (Alliance: 180 and 186)
AIM S/N: Specialagentjim
Unread 22-01-2003, 23:13
Umm Errr...
use a very short pnumatic cylinder.
1139 Alumni
Unread 22-01-2003, 23:40
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
Last year we used servo's to shift. It worked pretty well. We got sick of having to stop when we shifted, so we have redone our transmission Can you say 'Variable Speed Drive'?
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 22-01-2003, 23:43
545TheAmbasator 545TheAmbasator is offline
545TheAmbasator is an unknown quantity at this point
Send a message via ICQ to 545TheAmbasator Send a message via AIM to 545TheAmbasator Send a message via Yahoo to 545TheAmbasator
Programing
come on guys, there's a much easier way. program a max speed allowance then just add a trigger command that will allow you to switch to a higher speed. it's doable in not a lot of coding and with multi-bank programming it's like nothing to add in.
Unread 23-01-2003, 01:12
Jnadke Jnadke is offline
Go Badgers!
#0093
Jnadke is on a distinguished road
Send a message via ICQ to Jnadke Send a message via AIM to Jnadke Send a message via Yahoo to Jnadke
Re: Programing
Are you serious????
If you are... you might want to confer with the more mechanically inclined members of your team so they can edumacate you better.
The best moments of our lives fall in two categories: those that did happen and those that did not.
Unread 23-01-2003, 01:49
Jay Lundy Jay Lundy is offline
Programmer/Driver 2001-2004
Jay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to allJay Lundy is a name known to all
2001 we used a servo to shift. We got it working well so it never failed to shift.
2002 we built a custom transmission so we could shift on the fly, but this year we decided to try the new drill motor transmission that comes with the kit. We got the shifting to work with just a servo, and it has worked 100% so far (though we've only had a running base for a day or so).
Unread 23-01-2003, 08:20
AKA: Jim Martz
Re: Programing
::Must not flame..must not flame..must not flame::
Uhh....the theory you describe there won't really help you torque-wise..which is the point of having a tranny, so you can shift from High-speed to High-torque....
Unread 23-01-2003, 08:54
Bob's Avatar
Bob Bob is offline
AKA: Robert Kennedy
FRC #0084 (Chuck 84)
Bob is an unknown quantity at this point
Send a message via AIM to Bob Send a message via Yahoo to Bob
Last year we used servo's to shift. It worked great except you had to stop. The only other problem we had was that it would pop out of gear every once and a while. To solve that proble we used a coulple of springs.
Unread 23-01-2003, 10:03
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Re: Re: Programing
The whole point of shifting gear ratio in a drive train is to trade off between speed and torque. You have constant power from the motor, and since Power = speed times force, or angular velocity times torque, you get a combinations of speed and force from the motors depending your wheel size and your gear ratio.
By switching to a different ratio, you slow down your robot but you get more pushing force, or you speed up your robot but you have weaker pushing force. Controlling it in software only limit how much power you have from the motor, and thus making the motor weaker when you slow it down, instead of trading off speed for torque.
Few ways I've seen for shifting gear ratio: Drill motor's transmission using a servo or pneumatic cylinder, that's the most simple way for a team to shift gear ratio.
Have two sets of wheels with different ratio, and lower one set at a time depending what ratio you want. You can shift on the fly that way.
Custom gear box like team 45 and 60 last year, or the 67 bot at 2001, where you use pneumatics to move gears outside the drill transmission to from one ratio to another ratio. This is much more complicated, and if your team doesn't already know how to do this, I wouldn't start right with only a few weeks left in the 6 weeks.
Or, you can add more motors to your drive system, and get more mechanical power out of it that way. You have more overall power, and thus more torque and speed at the same time.
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 23-01-2003, 12:55
PaPPy PaPPy is offline
AKA: Brian Papile
None #0069 (HYPER)
PaPPy is on a distinguished road
Send a message via AIM to PaPPy
team 69 did the same in 2001 and 2002
We used pneumatics to shift on the fly for 2002 using the big atwoods i believe if you need a diagram i can find one just email me xdohhhx@aol.com
also to reply to the programming reducing it would work but not give you the same aspect as shifting.
This year we are going to have an awesome drive train again! Watch out NH and TX!
~-PaPPy-~
gear shifting Stephen Kowski Motors 19 30-03-2003 21:33
Segway-like device being developed by Honda MattK Dean Kamen's Inventions 17 23-11-2002 15:31
RoboStars 'Mini-Arm' Control Device archiver 2000 5 23-06-2002 22:28
Best Ball Collecting device of 2002 D.J. Fluck General Forum 32 07-05-2002 19:15
Like Device sasquatch General Forum 6 31-01-2002 08:51
