Go to Post On a side note... "Think outside the robot." - I kinda like that. I'll have to use that in a meeting someday.... - Not2B [more]
View Poll Results: What do you use for chassis material?
wood 11 5.07%
steel angle 8 3.69%
aluminum angle 36 16.59%
steel tubing (round or rectangular) 2 0.92%
aluminum tubing (round or rectangular) 58 26.73%
Bosch extrusion or similar (aluminum or steel) 89 41.01%
Other 13 5.99%
Voters: 217. You may not vote on this poll
  #46   Spotlight this post!
Unread 18-01-2003, 01:39
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Originally posted by M. Krass
I'm really interested in seeing what sorts of results you all have with the sheet metal.
We're using .19" sheet metal for our frame, with some beefier stuff mixed in here and there. I was a little scared of going thinner than that. We'll see how it shapes up in a few weeks, I guess.
Good luck.
Sheet metal is what the body of your automobile is made of. By golly I think what your talking about is honest-to-goodness 3/16" PLATE. That will do just dandy for any robot is my shop.
  #47   Spotlight this post!
Unread 18-01-2003, 08:16
Josh Fritsch's Avatar
Josh Fritsch Josh Fritsch is offline
Team 27 Mentor/Alumni
FRC #0027 (Team Rush)
Josh Fritsch has a spectacular aura aboutJosh Fritsch has a spectacular aura about
Nothing against extruded aluminum, cause i love it to death, except for the fact that it is just too heavy, so i think we are going to eventually go with the aluminum tubing, either round or rectangle. But i do know one thing for sure, we dont have the weight to spare this year..
  #48   Spotlight this post!
Unread 22-01-2003, 23:47
hi_im_sean hi_im_sean is offline
hi_im_sean is an unknown quantity at this point
we are using aluminum 2x4 tubing that came in the kit. it works well and is strong but we cant weld a lot of disimilar metals on it.
  #49   Spotlight this post!
Unread 23-01-2003, 12:48
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
We're going to use 3/4" square tubing for our bot this year. We're making a steel prototype, but the final version will probably be aluminum.
Jeff Waegelin
  #50   Spotlight this post!
Unread 05-12-2003, 03:13
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: Too heavy
Originally Posted by sidewinder
We are big fans of the 1" extrusion but in my pit scouting for the last few years i have noticed something, The robots built for first don;t have enough power to bend 1" extrusion with any kind of blow.
I beleive that 20 mm extrusion, very light by comparison to its big brothers, has more than enough strength for our purposes.
20mm extrusion is something that we've looked into too, and I think that's definitely a possibility to reduce weight, though rough calculations would show the moment of intertia would drop to about HALF that of 1" 80-20 just by reducing the overall width and height (and presumably weight) to roughly 80% (20 mm / 25.4 mm/in) . That's the one reason that we haven't made that switch. Has 20 mm been used by your team in the past?
To keep with the thread:
In the past two years we're always using 80/20, 1010 (1" x 1")... and here's why:
The moment of inertia of 80/20 1010, which is 1" x 1", is .04413 in^4
The moment of interia of 1" x 1" x 1/8 thick box is 0.0570 in^4
The weight of 80/20 1010 is 0.495 lbs / ft
The weight of 1" x 1" x 1/8 aluminum box is 0.511 lbs / ft
So.. for those of you trying to save weight, look again!
Check it out at:
http://www.8020.net/pdf/Fractional/0...%20(31-62).pdf
Obviously though, it's more expensive than box aluminum. We were purchasing it at around $2.50 a foot. Box aluminum is about $1.50 a foot off of www.onlinemetals.com
People tend to make assumptions... crunch some numbers and you'll be surprised what you find!
In addition, the ability to actually CHANGE your frame around makes 80-20 great stuff. You can buy a 100 pack of t-nuts for $.08 each and go to town. Where 80-20 makes all their money is on those brackets and corner squares at $18 each. We make our own and come out just fine.
Matt
  #51   Spotlight this post!
Unread 05-12-2003, 12:35
Madison's Avatar
Madison Madison is online now
Dancing through life...
FRC #0488 (Xbot)
Re: Too heavy
Though the 8020 extrusion itself may be lighter per foot than box aluminum, don't forget to factor in the weight of the additional fasteners and joining plates required to make it all stay together. If a team has access to aluminum welding equipment, it's probably lighter to weld a frame together from box aluminum than to make it from extrusion -- depending on its design, somewhat.
--Madison--
...down at the Ozdust!
  #52   Spotlight this post!
Unread 05-12-2003, 12:59
Matt Adams's Avatar
b(o_o)d
FRC #1525 (Warbots)
Post Re: Too heavy
Let's see.
If you're using say 25 feet of 1" 80-20 for your frame, you'll save about .4 lbs over box.
40 1/4-20 bolts at 5/8" long, 8 of those corner fasteners (about .025 lbs each) and prolly about a foot and a half of 1" x .125" angle (at .2742 lbs / ft) gives you fasterner weight total of about .752 lbs...
<math skipped, have faith in my algebra>
So using 1" 80/20 for your frame is about 3.1% heavier than box aluminum, fasteners included. (13.17 lbs vs. 12.78 lbs)
Absolutely worth it IMHO.
Image Discuss: Team 190 - Completed chassis CD47-Bot Robot Showcase 17 20-02-2003 17:37
Image Discuss: Chassis Teaser CD47-Bot Robot Showcase 4 10-02-2003 23:00
the provided chassis material Andrew Dahl Kit & Additional Hardware 5 09-01-2003 15:26
Sheet Aluminum Chassis: fs_2002 Technical Discussion 4 17-10-2002 10:10
Chassis ark_1230 Technical Discussion 2 04-09-2002 22:51
