Go to Post If said device costs 10x more to manufacture than a simpler solution integrating COTS parts, and only performs 10% better, that's poor engineering. - Cory [more]
Unread 07-01-2002, 08:17
ctartist236's Avatar
ctartist236 ctartist236 is offline
AKA: David B Mittelman
FRC #0236 (Techno Ticks)
ctartist236 has a spectacular aura aboutctartist236 has a spectacular aura about
Send a message via ICQ to ctartist236 Send a message via AIM to ctartist236
Question custom circuit boards
I need some help. I need to find a circuit design for a digital ampmeter. Does anyone know where I can find one? Better yet, does anyone have one? We are looking to test up to 200 amps. I need all the help I can get.
Unread 07-01-2002, 08:53
bigqueue bigqueue is offline
#0811 (A.R.C.)
bigqueue will become famous soon enough
Send a message via AIM to bigqueue Send a message via Yahoo to bigqueue
Lightbulb
Someone noted that you can measure the voltage drop across a measure of wire. Yes, you would have to probably make that wire long to get a high enough resistance to measure.....but it is possible.
Now, why not just add a very small resistor in series....because it does not seem to be allowed. The rules say that the high impendence inputs of a circut may be attached to some number of points described, but it clearly indictates that this is OK because it does onto affect the circuit appreciatbly.
Placing a series resistor violates all the rules regarding how one MUST wire all the motors/spikes and other controllers......so it would be against the rules.
Still, the job is not as hard as it seems.....and with an op-amp or two (depeending on whether you need to build a true DIFFERENTIAL AMPLIFIER or if you can get a good common ground reference point).
There are of course other ways to do such a measurement using the magnetic radiation off the wire as current flows. I think this might be the better, more noise-free way to skin this cat.
-Quentin
Team 4987: Megarams
Unread 07-01-2002, 10:47
ErikJusten ErikJusten is offline
#0677 (A Few Screws Loose)
ErikJusten is an unknown quantity at this point
As far as using fields to measure DC current, those sensors aren't cheap, and I'm pretty sure they aren't in Digi-Key's catalog (Newark carries some, but they are a little pricey (~$75, if memory serves me correctly), and aren't allowed anyway). Now AC is a whole different story - those are easy to find. But.......... that's not really point........
Erik
(who has spent a lot of time thinking about this exact question)
Unread 07-01-2002, 15:50
#0811 (A.R.C.)
I'm not sure that these work as well as you mite like because some of them require differential power supplies, but take a look at this:
http://www.digikey.com/scripts/us/dk...9&Cat=23265747
They seem to range from $19.00 to $50.00...which fits in the budget.
Team 4987: Megarams
Unread 07-01-2002, 19:18
Greg Ross's Avatar
Grammar Curmudgeon
AKA: gwross
FRC #0330 (Beach 'Bots)
Hey Q, Just exactly what were you trying to point us to? When I tried the URL you gave, DigiKey.com told me "your dataset has expired."
Unread 08-01-2002, 00:10
#0811 (A.R.C.)
Red face
Oops....sorry.
Well, go to Digikey and look for the following Digikey part number:
398-1011-ND
This is a 100 Amp LEM Inc. Transducer. These seem to come from 6A to 150A max.....some run off 5v, and others +/- 15v.
I hope this helps.....
-Quentin
Team 4987: Megarams
Custom Circuit Boards Billius Electrical 7 14-04-2003 12:48
message boards, chat rooms, etc archiver 2001 9 24-06-2002 03:55
circuit breaker archiver 2001 2 23-06-2002 23:18
So what's in YOUR Custom Circuit this year? kmcclary Technical Discussion 7 10-04-2002 12:20
Wiring custom toggle switches into operator interface DanL Electrical 9 13-02-2002 17:13
