Go to Post In the end, if our products are crap, then people will not buy them. This is the risk of doing business, and the foundation of capitalism. - Andy Baker [more]
Unread 25-01-2003, 10:52
jdawson jdawson is offline
#0910 (Decoma/Foley)
jdawson is an unknown quantity at this point
multi rotational potentiometers
Can anyone help me with this?
I have a multi rotational pot that reads 0-254 in one turn of the pot but I need to read 0-254 in 4 or 5 turns. The pot I have is Digikey number 3590S-1-104 it is a 100k wirewound 2 watt.
Unread 25-01-2003, 12:17
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
:warning i dont know alot about pbasic:
you could probably change the way it is reading the number by like dividing by something
or you could gear the pot so that it will turn more then if you just turned the shaft on it..
I'm not good at explaining what i want to say but u might get the idea.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 25-01-2003, 13:15
Can't use a gear don't have the room.
Unread 25-01-2003, 13:33
what about a pully?
or a single turn pot?
Unread 25-01-2003, 13:37
I don't have the room and what I am trying to read turns four times!
Unread 25-01-2003, 13:40
i'm outa ideas...
Unread 25-01-2003, 14:04
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
DigiKey carries multi-turn pots.
They have a listing for ten-turn pots on pages 751, 752, 764, and other various multi-tun pots around there, but the accuracy you'll get out of a ten-turn pot is about half of what you'd get if you were to use a five-turn pot, as your need only takes four turns, but apparently, unless I didn't look hard enough, DigiKey doesn't carry five-turn pots.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Unread 25-01-2003, 16:00
we've used these before.
Unread 27-01-2003, 08:12
Another solution might be counting something (slots in a fan-like disc on a shaft, a paint spot, teeth on a gear or sprocket, etc) using a PIC, and reporting it via a serial A-to-D.
Ten turn pots are the neat solution, if you can get enough resolution. By the way, is there a restriction on how small your gears have to be ? Driving a pot probably doesn't require steel gears 1/2" thick. You probably have servo motor gears you could use.
If your are not to worried about precsion (only need a few bits), pots are made that have no stop. The resistance is not complete in the small angle between the ends of the resistance element. You'd have to read the resistance, and also count the number of times it went through 255.
A caution: Three turn pots are available: they have a 1/4" control shaft that becomes thin, and the thin part drives 3 balls around in a race formed in the cover (a rough and ready planetary system), on the side away from the mounting bushing. They are used for calibration adjustments (eg, in pH meters). I suspect that they might not maintain a linear relation between angle an resistance (they might slip This doesn't matter in a pH meter where the operator just keeps turning until the effect is right.
Multi Drive Fun... Sachiel7 Technical Discussion 14 13-10-2003 01:06
Multi Speed Dual Motor Gearbox tenfour General Forum 14 08-09-2003 13:09
Multi Subwoofer wiring - which amp to use? -- Help!!! Elgin Clock Chit-Chat 9 22-02-2003 20:07
Working with Potentiometers GrahamS314 Programming 11 02-02-2003 14:34
Multi Motor Drivettrains Ryan Curry Technical Discussion 9 08-04-2002 08:18
