Go to Post So, the game hint is there is no game hint. - tindleroot [more]
Unread 25-01-2003, 11:49
jdawson jdawson is offline
#0910 (Decoma/Foley)
jdawson is an unknown quantity at this point
Relay outputs on rc
Relay outputs 6,7,8 are not working on the robot controller. Does any one know what could be wrong? I have moved the output to other relay out and they work fine just them pin numbers.
Unread 25-01-2003, 14:24
nragod's Avatar
nragod nragod is offline
AKA: Ed Jordan
None #0376 (Newark Robotics Assoc.)
nragod is an unknown quantity at this point
Send a message via ICQ to nragod Send a message via AIM to nragod Send a message via MSN to nragod Send a message via Yahoo to nragod
it could be the programming
Unread 25-01-2003, 14:35
But the relays work when I program them to a different pin output. relay8=1 don't work, relay4=1 does work
Unread 26-01-2003, 12:36
Relay 8 is turned on in the forward mode (and off in the reverse), fairly well on in the default program. (It is used for the rotating beacon, which is always on.)
Perhaps you have a statement that tries to turn it on, but later in the loop it runs into the default code for setting the beacon, and you instructions are lost. Similarly, the code about the switches controlling the relays is way down, and maybe you have overlooked it.
Perhaps the pins sticking up from the circuit board are unstuck. If so, IFI should be phoned. They are very good in such emergencies. I'm assuming you haven't checked (or have no one who can check) the pins' connections or you'd have mentioned it in your post.
Unread 26-01-2003, 12:51
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Is it just 6,7,8 or is 5 not working too? If 5 doesn't work, I'd check your SEROUT to make sure relayB is in the correct place as all four of the above relays get their information from this same byte.
If 5 is working, try setting relayX_fwd=1 immediately before the SEROUT to make sure none of the possibilities Lloyd mentioned are occuring.
relay and pwm outputs nick_champ_2 Electrical 1 31-01-2003 13:08
Wiring the relay for the pnumatics Placebo OCCRA 3 05-11-2002 23:04
Spike Relay Input nwagers Electrical 3 16-07-2002 22:23
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
Relay Outputs OddOne Technical Discussion 3 01-02-2002 19:52
