Go to Post These folks have bigger hearts than most. I think they grow them that way in Indiana. - JaneYoung [more]
Unread 25-01-2003, 20:21
davidzhang davidzhang is offline
davidzhang is an unknown quantity at this point
Send a message via ICQ to davidzhang Send a message via AIM to davidzhang Send a message via Yahoo to davidzhang
visibility of robot controller?
just one quick questions:
our robot's electronics is completely enclosed by a box created out of sheetmetal. however, there is a rule in the robotics manual saying that the robot controller needs to be visible during the match. the question is how visible does the robot controller need to be? does it have to be visible from the sidelines or can it be completely enclosed and only visible at certain angles?
thanks,
david zhang
Unread 25-01-2003, 20:36
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
it needs to be pretty visible. the referees usually want to be able to at a quick glance, check and make sure no error lights are on. during a match, it's not an issue, but when setting up before a match, it's kinda important. it's also important for you to know if there's a problem.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 25-01-2003, 21:28
Ryan Foley Ryan Foley is offline
FRC #5687 (The Outliers)
Ryan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond reputeRyan Foley has a reputation beyond repute
i believe that it needs to be visible so that the LED indicators on the RC can be easily seen, although I'm not 100% sure.
Ryan
FRC #5687: The Outliers [2015-?]
FRC #1995: Fatal Error [2007-2009]
FRC #350: Timberlane Robotics [2001-2004]
FRC/FLL volunteer since 2005
Unread 26-01-2003, 00:17
evulish's Avatar
evulish evulish is offline
1010100
AKA: Grant Harding
#0084 (WATTNESS (bot: Chuck))
evulish is just really niceevulish is just really niceevulish is just really niceevulish is just really nice
Send a message via AIM to evulish
It's quite useful for the drivers...you can tell what's wrong sometimes without moving. Lights are nice...
I'm a professional web developer. I'm good with PHP, Perl, Java/JSP, some RoR, XML, Javascript (AJAX as well), (x)HTML, CSS, etc.. Validated code is good; fully cross-browser code is better (you comply to your users and the software they use, not the other way around. Sorry!)
Unread 26-01-2003, 01:04
http://jive.ilearning.com/thread.jsp...9&message=2661
Unread 26-01-2003, 01:11
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Last year we had the controller mounted like 6 inches below a piece of lexan the same size as the controller with a bunch of sickers on it and it was okay.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Visibility of Robot Controller and Reset Button Tracy Rules/Strategy 1 17-02-2003 07:36
Controlling a FIRST robot with a Lego RCX Controller? archiver 2001 5 24-06-2002 04:19
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
