Go to Post Yeah refs are trained to not have a sense of humor about things like that. - Koko Ed [more]
  #31   Spotlight this post!
Unread 27-01-2003, 13:00
Ameya's Avatar
Ameya Ameya is offline
Freelance Goon
FRC #0293 (SPIKE Robotics)
Ameya is on a distinguished road
Send a message via ICQ to Ameya Send a message via AIM to Ameya
Originally posted by rbayer
I'm not going to argue over this one: x86 (and most other architectures) use two's complement for representing negative numbers. Under that system, you invert all the bits and add 1. It's just the way it is. Don't believe me? Go ahead and read this.
No need to argue, since you're both right. Rwaliany is using the actual definition of two's complement (the highest bit represents the opposite of what it does in an unsigned int (so 10000000 = -128 if it's a signed bit and +128 if it's unsigned)). Rbayer is using an easy shortcut to calculating the two's complement.
Ameya Agaskar
Team 293 alumnus
  #32   Spotlight this post!
Unread 29-01-2003, 03:16
Gobiner Gobiner is offline
#0753 (High Desert Droids)
Gobiner is an unknown quantity at this point
Send a message via ICQ to Gobiner Send a message via AIM to Gobiner
A skillful programming isn't limited by the law, either. Wait, what I meant to say was that a skillful programmer is limited by the language, at least when we're talking PBASIC. I'd like to see someone who can make their robot do differentiation. If you're talking QBASIC versus C, then it doesn't matter. PBASIC simply doesn't do alot of things. The difference is in the context. PBASIC could do anything a person could ever want their robot to do, if they're smart enough and can devote the time to doing it. If you couldn't do everything feasible/useful I think FIRST would change things.
0N3 1337 PR0G|24MM1N6 N1NJ4
Obscure PBASIC for RoboEmu rbayer Programming 1 28-03-2003 23:57
PBasic 2.5 vs. 2.0 Anthony Kesich Programming 6 09-02-2003 22:06
RoboEmu v.1a (another PBASIC emulator) rbayer Programming 0 07-07-2002 00:45
emulationFIRST (aka PBasic emulator) Matt Leese Programming 5 30-06-2002 12:06
Another PBASIC Question Ian W. Programming 4 31-01-2002 21:36
