Go to Post The minute you get a functioning mechanism start working on a better one - [more]
Unread 26-01-2003, 12:43
Steven Carmain Steven Carmain is offline
Bit Twiddler
FRC #2832
Steven Carmain will become famous soon enough
Solution to Timing Loops
I have found out how to time. Based of the information from Innovation First, a loop is every 26.2 ms, assuming your code does't lengthen it. Based off of that, there are 38.167938931297709923664122137405 loops per sec. So to do close timing without overloading the stamp, you do:
Time VAR byte
RealTime VAR byte
Time = Time + delta_t + 1
if Time > 38 then
Time = Time - 38
RealTime = RealTime + 1
EndIf
This way only uses 2 bytes insted of a byte and a word. I tryed the delta_t * 262 / 10 but it overloaded the stamp and was very inaccurate.
Based of of this formula, then the basic stamp will be 0.530431579 seconds fast at end of match.
You can check this information on this xls I inclosed.
2017 - Team 2832 Mentor
2016 - Team 6013 Mentor
2002-05 - Team 45 Software/Electrical
A robot is like a campfire: it takes a while to bulid it, and then everyone surounds it!
A world without standards is chaos. A world with standards is chaos.
Unread 26-01-2003, 15:31
Anthony Kesich's Avatar
Anthony Kesich Anthony Kesich is offline
Programmer Turned Engineer
AKA: SonKenshin
#1097 (Site 3 Engineernig)
Anthony Kesich has a spectacular aura aboutAnthony Kesich has a spectacular aura about
Send a message via AIM to Anthony Kesich
Thumbs up Dear god thats great
i must applaud you for your idea. I myself, being a rookie programmer on a rookie team, am just getting the hang of the language, but after reading the forum got this idea yesterday, but then flushed it out, on one basis. doesn't delta_t count the total number of packets missed since starting the program?
-Anthony
C is screwing up my English--I'm ending all my sentences in semi-colons;
Horray for most things! -George Carlin
"Sure, I'll play rugby. Besides, I have a lot of experience running from really big guys who want to cream me." -Me, Freshman year
Unread 26-01-2003, 15:40
Noah's Avatar
Noah Noah is offline
Code Monkey
#0861 (The Gondobots)
Noah has a spectacular aura aboutNoah has a spectacular aura about
Send a message via AIM to Noah
Re: Dear god thats great
Originally posted by Anthony Kesich
[Bdoesn't delta_t count the total number of packets missed since starting the program? [/b]
No, delta_t counts the number of missed packets since your last serin. it gets reset to 0 with each serin.
"It's broken? NOOAAHH!!! This is your doing, isn't it!"
"We can fix it in the software!"
"It's a BROKEN GEAR!"
Unread 26-01-2003, 16:07
AKA: SonKenshin
thats good to hear, you always want to check your bases. you know, play it safe.
-Anthony
Unread 26-01-2003, 21:19
Bit Twiddler
FRC #2832
Did you get the xls. If you guys didn't, then can I have a email address if you want a copy or to post it in the internet
Unread 26-01-2003, 21:23
Noah's Avatar
Code Monkey
You can attach it to your post as a file. That would probably be best. That way everyone can download it straight from here.
Unread 27-01-2003, 08:08
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
Re: Solution to Timing Loops
How is this possible? Unless you use only the default code, this number will change, and you have to change the code if you are going to do anything automated.
It's really not that hard to just figure out the numbers by guess and check.
You can do a timer with 2 bytes too, only difference is that you can only count to 255, and when you reach this number you simply start a new step, as documented in my programming sample in the white papers.
Unread 27-01-2003, 08:17
Bit Twiddler
FRC #2832
If you do the research like I did, then you would see that a loop is 26.2 ms a loop. If your code is shorter then you wait at serin until you get the information and start the loop over. If you take too long in your code, then the delta_t comes in. It count the number of loops you missed as long as it is in the serin. If you miss 5 serins then you have the basic run error. So in theory, this should be accurate.
Unread 27-01-2003, 22:32
AKA: SonKenshin
Talking
all i know is this code works. I played with basic autonomous mode today (this isn't that sad, seeing as i am the only real programmer at my school, this is a rookie team, and i have taught myself almost all of the code) and this works like a charm. Since most people only use timing in auton mode, you will only be off by about .066 seconds, and that is extremely insignificant. (It was so little that i didn't notice at all)
-Anthony
Unread 27-01-2003, 22:47
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
one question. why the timing loops? why not just a counter?
i made a little program a few days ago, all it does is use a byte and a nibble, and based on the counter and nibble advances through a select case. all you do to control it is adjust the byte to how high to count, and always advance the nibble by one. you can get up to 18 operations in this way, actually more if you don't use the full 255 loops from one byte at a time.
if this doesn't make sense, i'll post the code tomorrow afternoon when i find it. it's very simple when you see it, and it works fine. no need to worry about time, because if the loop gets longer, even a timer would get screwed up.
AIM --> Woloi
Email --> ian@woloschin.com
Unread 28-01-2003, 19:33
Greg McCoy's Avatar
boiler up!
Yeah, that's pretty much what I did. It seems to me that it does the exact same thing with less complexity and the exact same efficiency if done correctly.
Unread 29-01-2003, 16:36
mjt902 mjt902 is offline
mjt902 is an unknown quantity at this point
First, this thread starter knows what he's talking about. Second, a counter counts loops. The number of loops you get in one second changes. Don't believe me:
copy a simple statement 100 times, or use some calc in your program and see how slow the counter goes.
I can forsee that this years coding is that complex when compared to last years (all we needed were a few if statements). The delta_t is the only TRUE thing in your code, so it is imperative that you do the auton mode the way suggested, and do NOT use counters.
GUESS AND CHECK IS NOT HELPING US LEARN ANYTHING
Top Ten Reasons to Procrastinate:
1.
Unread 29-01-2003, 17:03
College? What?
uh, i can control how long it does something based on counting with cycles AND delta_t. it's the same as a timing loop, minus the extra memory and added difficulty. and i've seen no problems so far with my code. sure, it aint pretty, but it's dead reckoning, it's not supposed to be!
AIM --> Woloi
Unread 29-01-2003, 18:17
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
There is no advantage to converting Stamp loops to "real" time. It is a 1-to-1 conversion, meaning that each "real" time value corresponds to some fixed number of loops and vice-versa. For example, the following code would do exactly the same thing:
loopCnt VAR byte
loopCntHigh VAR nib
loopCnt=0
loopCntHigh=0
SERIN...
if (loopCnt + 1 + delta_t > 255) then loopCntHigh=loopCntHigh + 1 : loopCnt=loopCnt+1+delta_t-255 else loopCnt=loopCnt+1+delta_t
SELECT (loopCntHigh<<8 + loopCnt)
CASE range1Low TO range2High
  'do stuff
CASE range2Low TO range2High
  'do other stuff
CASE ELSE
  'do even more stuff
ENDSELECT
SEROUT...
This will let you count up to 4096 loops, which is approx 1min 45s worth of autonomous time. Plus, it only uses 1.5 bytes!
Questions about the above stuff? Email or PM me and I'd be more than happy to explain.
Unread 29-01-2003, 18:36
Once again you correct me!!! Oh, I'm lazy anyway but thanks for the free code. Only one question have I:
where'd you get the 8 from in SELECT(loopCntHigh<<8 + loopcnt)
i think you and i are on the same page (only i'm on a different plane) , and its great learning from you!!!
1.
Timing of nats for next year Ian W. Championship Event 13 03-03-2003 18:28
Way back there. Size of Nationals, and a solution archiver 2001 23 24-06-2002 03:28
what is or isn't a timing belt? archiver 2001 6 23-06-2002 23:26
two sided timing belt archiver 2001 3 23-06-2002 22:34
Dual Sided Timing Belts Lachuck894 Technical Discussion 9 14-01-2002 10:10
