Go to Post I'm 5'5", and I'm our team's drive coach. Our drivers are nearly always taller than me. In my case, it's not the driver's station that needs to be made of lexan...it's our drivers. - StephLee [more]
Unread 03-02-2003, 10:50
KZos550's Avatar
KZos550 KZos550 is offline
#0550 (WCTS Knights)
KZos550 is an unknown quantity at this point
Send a message via AIM to KZos550
Exclamation Using a switch before autonomous operation
Is it legal for the human player to flip a switch for the movement of the robot (during the autonomous time) when they place the robot down on the field? The switch is changed on placement of the field, and the input of the switch is read during the auto period.
The Zos Has Spoken
Unread 03-02-2003, 11:24
Mike Soukup's Avatar
Mike Soukup Mike Soukup is offline
Software guy
FRC #0111 (Wildstang)
Mike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond reputeMike Soukup has a reputation beyond repute
It's absolutely legal. Most teams will have a similar setup, to either tell the robot which side of the field its on, or to switch between programs.
Unread 03-02-2003, 11:41
In fact, Woody even suggested this at kickoff.
Unread 03-02-2003, 11:42
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Totaly legal. We have a small one now we are using durring testing.
Unread 03-02-2003, 17:55
KZos550's Avatar
thakns
I was just freakin out today during a programming binge with the other programmer on the team. Thanks
The Zos Has Spoken
Unread 03-02-2003, 19:02
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
Is this switch for the Human Player to throw or the drivers moving the robot on to the field. Remember 10sec is not long to move boxes and flip a switch. People who have tried on my team have had problems just getting the boxes out in the 10 sec. So I would proably just have the drivers do it.
Andrew Radamis
Programmer on 862
info@lightingrobotics.com
Unread 03-02-2003, 19:05
KZos550's Avatar
I believe that should answer your question
The Zos Has Spoken
Unread 03-02-2003, 19:16
rust710's Avatar
Silly me. Mabey I should be more careful while reading the posts.
Andrew Radamis
Programmer on 862
Unread 03-02-2003, 19:19
KZos550's Avatar
its ok
Hey, at least I got some use practicing quoting...
The Zos Has Spoken
Unread 03-02-2003, 19:24
rust710's Avatar
Re: its ok
Can't you just hit the quote button toward the bottom of the post and delete what you don't want? Like what I did above.
Andrew Radamis
Programmer on 862
Unread 04-02-2003, 15:02
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
cool switch
Digi-key part number CKN5029-ND, $10.38. This is a one-digit thumbwheel switch with BCD output. It has a small mechanical digit that increments/decrements by pressing one of two little buttons on it. The output is 4 bits representing 0-9, so you get 10 possible combinations. You can get 8 combinations (0-7) using only three of the outputs if you're tight on space.
Unread 04-02-2003, 19:12
KZos550's Avatar
<psarcasm> no, I cant just quote the normal way. I have to do it the hard way making lines and frames and stuff and guess approximately what people said in their posts, instead of actually copying and pasting.</psarcasm>
I was joking...
The Zos Has Spoken
A better autonomous method.. randomperson Programming 4 24-02-2004 18:02
variable? manodrum Programming 11 01-04-2003 17:20
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
Autonomous Kill Switch UCGL_Guy Programming 8 15-01-2003 17:39
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
