Go to Post FIRST has the power to change lives, inspire, and make dreams come true. - Jaine Perotti [more]
Unread 03-02-2003, 19:58
great_one411 great_one411 is offline
#1210 (NYACK)
great_one411 is an unknown quantity at this point
Question how do you power on the robot control
My team wants to know how do you power up the robot control, if the adapter only fits into the operator interface. PLEASE GIVE US SOME USEFUL INFORMATION.
Unread 03-02-2003, 20:00
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
the robot controller is powered from the battery onboard the robot.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 03-02-2003, 20:03
Darwin695 Darwin695 is offline
#0008 (Paly Robotics)
Darwin695 is an unknown quantity at this point
Send a message via AIM to Darwin695
the robot control unit is powered by two twelve volt screws. run these through your twenty amp breaker. these screws are on the right side of the "Program" plug and say "12 volts".
I build it,
My brother destroys it
Unread 03-02-2003, 20:06
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
You might want to go and get a mentor very quickly
These question can be answered by your mentor
Good Luck
Unread 03-02-2003, 20:47
Frank(Aflak)'s Avatar
Frank(Aflak) Frank(Aflak) is offline
#1067 (SLUH)
Frank(Aflak) is on a distinguished road
Don't worry, reverse current wont hurt it.
We found that out after trying and trying to get it to come on . . . only to realize that the quick release thingy on our battery was backwards . . . . I didn't breath again until we tested it and it came on.
Unread 03-02-2003, 21:06
Lord Nerdlinger Lord Nerdlinger is offline
Lord Nerdlinger has a little shameless behaviour in the past
yes, get a mentor, very quickly, that or read a book, or the white papers or something.
Unread 04-02-2003, 00:46
Although the Robot controller has a protection diode built in, it is not failsafe. Damage can result if the polarity of the supply is reversed. As to the correct way to connect the robot controller, please refer to the controller manual available here... http://www.innovationfirst.com/FIRST...umentation.htm and the robot electrical drawing here...
http://www2.usfirst.org/2003comp/rob..._blueprint.pdf
These two documents should be able to give you an definitive answer. If you are still unsure, let me know and I will explain anything that you are not sure of.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
RoboCon 1.01 (control robot from PC) rbayer Programming 20 06-11-2002 21:30
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
Control System Power Al Skierkiewicz Technical Discussion 0 25-03-2002 09:04
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
