Go to Post Ahh yes, the good old "let's dedicate all our resources to absolutely cheesing the opponent alliance" strategy - Jaci [more]
Unread 06-02-2003, 21:04
Skabana159's Avatar
Skabana159 Skabana159 is offline
Robotics and Field Hockey
AKA: Jesse C. Owens
#0159 (Alpine Robotics)
Skabana159 is on a distinguished road
Send a message via AIM to Skabana159
Problem with communicating with STAMP through serial port
Our team's been trying to build a custom circuit board that provides extra sensory information to the STAMP. However, we've been encountering troubles with the SERIN command in STAMP. It seems that the STAMP sends an echo byte of its own whenever output is processed through the serial. Does anyone have a similar problem like this?
"What most people do not understand is that the Buddha, the Godhead, resides just as comfortably in gears and circuits as in hills and trees. To believe otherwise is to dilute the Godhead."
-Robert Pirsig, Zen and the Art of Motorcycle Maintenance
Unread 06-02-2003, 21:05
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
You are correct, the Stamp echos everything that is sent to it. Unfortunately, there is no way around this.
Unread 06-02-2003, 21:10
Skabana159's Avatar
AKA: Jesse C. Owens
I just realized what I type doesn't quite make sense.
Basically, we have another microcontroller on the circuit board which process the readings from sensors and send them to the STAMP through the serial port.
We programmed the STAMP to send an handshake byte to the microcontroller, which upon receiving the byte, sends over the sensor readings. We have the baud rate set at 9600. However, what is interesting is that whenever the STAMP receives the data, it sends an echo byte to the microcontroller. I don't know if this is the reason why we are having serious problem.
We have checked each subsystem with a terminal program and they all work fine on their own. The problem is when we attach the two serial ports together.
Win32 serial port - recieve buffer seanwitte Programming 4 05-11-2003 21:41
Impending BASIC Stamp Editor Beta 2 release Greg Ross Programming 9 19-09-2003 06:05
How to communicate both through radio and serial port? JC Denton Programming 1 08-02-2003 23:43
Ever seen this serial port problem before??? Aidan F. Browne Programming 5 05-02-2003 12:03
Serial Port Communication White Paper rbayer Programming 87 14-06-2002 16:10
