Go to Post Things that get said on the field should stay on the field. - Bongle [more]
Unread 09-01-2002, 16:31
P.J. Baker's Avatar
P.J. Baker P.J. Baker is offline
needs a clever user title
FRC #0177 (Bobcat Robotics)
P.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of lightP.J. Baker is a glorious beacon of light
Extremely cheap soccer balls
We just purchased a bunch of soccer balls from the Spaulding Factory outlet in Chicopee, MA. We only paid $2.50 each - that is not a typo. Apparently they are left over from some sort of promotion. Here is the info I have:
The Spalding Factory Outlet, 521 Meadow Street, Chicopee, MA 01013
(1.413.322.2056) has 3,000 #5 soccer balls available at a cost of $2.50 per
ball. These are stitched balls manufactured in Pakistan and have latex
bladders. They are 28 grams heavier than the BOM Puma ball and are not
guaranteed to conform to the International Performance Specifications but
appear to be a low cost alternative which is readily available. The inflation nipple is not
recessed as well as the BOM ball and the surface finish is slightly
smoother. Please use your own judgement whether these balls will meet your
needs.
Spauding told us they would ship just about anywhere.
I've attched a picture of the ball.
Good Luck!
P.J.
Unread 09-01-2002, 20:50
Mike Martus's Avatar Unsung FIRST Hero
Mike Martus Mike Martus is offline
FRC #0051 (Wings of Fire)
Mike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond reputeMike Martus has a reputation beyond repute
Balls
Please remember that while they may be a size 5 they are not the same as the balls (Puma) that FIRST is using. That may cause you a problem because of the ball surface.
All soccer balls are not equal.
Mike Martus
Unread 09-01-2002, 21:18
Jeff Waegelin's Avatar
El Jefe de 148
AKA: Midwest Refugee
FRC #0148 (Robowranglers)
Re: Balls
True, but they are close. Unless your robot requires exact tolerances (big no-no), a ball that is a little off spec shouldn't matter. In any case, they should be closer to spec than the eggs we've used in past years.
Unread 09-01-2002, 23:50
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Snack Pack??? Like the Hunt's Snack Pack Pudding???? I think I remember that promotion!!!
Cool Beans!
Unread 10-01-2002, 16:31
D.J. Fluck
Posts: n/a
Re: Re: Balls
That’s not necessarily true.... different companies use different pressures....if they want to be considered a FIFA approved ball it must be within certain pressure limits and diameters....but FIFA is really lenient on the rules....as long as it comes withing about 6-8 PSI well its ok...(thats a rough estimate)
Basically what im trying to say is that maybe the ball you bought recommends a higher or lower PSI then what FIRST's balls are using....but you must be careful because the ball may not work right if you try to adjust the PSI to FIRST specs...If its not made for FIRST specs...practice runs with your robot may not be completely accurate
Ohby the way, FIFA is the organization that runs professional soccer all over the globe
Unread 10-01-2002, 18:41
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
cost
Is it true that the soccer balls that first is going to use cost 80$$$???????
If so thats a major rip off!!!!!!!
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 10-01-2002, 19:21
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Smile Last Time.....
Last time i'm answering a question about soccer ball size/brand/price/where to get them....
Online u can buy them for $14.99....so your rumor is incorrect.....even some of the best balls dont cost $81....
Purdue Alumni
Cummins, Inc.
Unread 10-01-2002, 19:49
Cost of balls
I purchased 20 balls (orange of course ) and they were exact units. $15 plus shipping at "Soccer World".
Mike Martus
Unread 10-01-2002, 20:48
D.J. Fluck
Posts: n/a
Those balls may have been $80 when they first came out...they are nice balls....
they now are out of production...from what i can tell
The physics of... soccer balls? Gui Cavalcanti Chit-Chat 9 18-08-2002 16:19
Team 188 Pictures - four big balls anyone? archiver 2001 6 24-06-2002 01:03
Will ANYONE mess with the black balls? archiver 2001 0 23-06-2002 22:35
Mini Web hug and an idea I have... Ken Leung Regional Competitions 24 18-03-2002 17:59
Game Balls? Nate Smith General Forum 22 08-01-2002 09:13
