Go to Post one wrong move and you could end up capping one of the judges. that will pretty much ruin your chance at judges' award - Mike Ciance [more]
View Poll Results: What do you use to power your chassis?
Drill Motors 41 41.84%
Atwood Motors 9 9.18%
Drill + Atwood 42 42.86%
some other funky combo 6 6.12%
Voters: 98. You may not vote on this poll
Unread 26-01-2003, 12:20
Solace's Avatar
Solace Solace is offline
Head Hurts. Coffee. More. Now!
AKA: Jake
#0571 (Team Paragon)
Solace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to beholdSolace is a splendid one to behold
Send a message via AIM to Solace
i think you misunderstood. I didn't mean putting a drill and a atwood together on a single drive train, i meant having each seperate wheel controlled by a seperate (singular) motor.
...What is a man,
If the chief good and market of his time
Be but to sleep, and tool? A nerd, no more.
2004 UTC New England #2 seed
2004 UTC New England Champions with 716 & 230
2004 Archimedes #2 seed, undeafeated in Qualifiers (for what its worth)
Jake
Team Paragon #571
Unread 26-01-2003, 14:07
Lauren Hafford Lauren Hafford is offline
#0159 (Alpine Robotics)
Lauren Hafford is an unknown quantity at this point
Send a message via AIM to Lauren Hafford
That's us, except we went with the Fisher Price because they were smaller and coupled better (easier i guess) with the drills. We're building our own transmissions for the first time and lemme tell you, it's a BLAST!! Hopefully it'll work out...we'll see at San Jose!
lauren
Unread 26-01-2003, 14:14
Bduggan04's Avatar
Bduggan04 Bduggan04 is offline
I bent my wookie...
AKA: Bryan Duggan
#0027 (Team Rush)
Bduggan04 will become famous soon enoughBduggan04 will become famous soon enough
Originally posted by GregT
Its a programming nightmare either way, you just don't know how bad it is when they are coupled
And your efficiency does drop dramatically when coupling motors- they fight eachother - but who cares in a 2 min match?
Greg
They don't fight each other if you gear them to the same rpm. The efficiency doesn't drop that much as long as you gear for the "sweet spot" in each of the motor curves.
As for programming goes, it's no different. You could run both speed controllers off of one pwm and the programming is no different than it is for one motor.
Unread 26-01-2003, 19:57
Harrison's Avatar
Harrison Harrison is offline
None #0783 (Mobotics)
Harrison has a little shameless behaviour in the past
Originally posted by BBFIRSTCHICK
we have 2 on each side, and used gear ratios
Same here.
(watch for pics to be uploaded soon)
Harrison Ruess
2002/2003 Team 783 Captain
UOIT '08 Alum
Unread 26-01-2003, 20:11
BBFIRSTCHICK's Avatar
BBFIRSTCHICK BBFIRSTCHICK is offline
Someone find me a FIRST team
AKA: Adriana
#1077 (was: All Stars)
BBFIRSTCHICK is on a distinguished road
Send a message via AIM to BBFIRSTCHICK
Originally posted by Harrison
Same here.
Harrison,
What do you use to switch from low to high gear...servos or pneumatics...or something else??
Team 59 "Ramtech": 2000-2002
Nationals 2001: Galileo Division Champions, National Semi-Finalist
Team 1077 "All Stars": 2002-????
Semi-Finalist, Peachtree Regional 2003 (507 and 356 Rock!)
Unread 26-01-2003, 21:53
Dick Linn's Avatar
no team (Synergy)
From the specs I saved, the Chiapua motors had just slightly less power (less than 10% differential) and a lot more torque. At stall, the Chiapua had 315 oz-in of torque. The 2002 drill motor was 650. mN-m at stall, which is about 92 oz-in. I'd expect 3 times the torque with all the copper and magnets in that big motor!
And don't be fooled by the torque specs with the drill gearbox...I'm talking the motor only.
Richard Linn
Co-founder Team 975
KIA, Iraq 1/26/2005
Unread 27-01-2003, 10:05
gc02 gc02 is offline
gc02 is on a distinguished road
If you gear two different motors to have the same output speed, the one with more power will also have more torque. This does not necessarily mean the drill motor is a better choice because with both motors geared to the same speed the Chalupa motor will probably have a lower effective mass and accelerate faster.
Greg
Enigma Industries
Unread 08-02-2003, 01:07
jed374 jed374 is offline
jed374 is an unknown quantity at this point
Using Drill and atwood motors
For those of you using both the drill motors and the atwoods, I am wondering how you are planning on programming the motors. I ran into a few problems, we want to beable to use drill motors on the front and atwoods on the back, and basically moniter the wheels so one doesnt spin faster than the other. Basically we made a speed-o-meter and if one is spinning faster than the other, they correct themselves. Heres the problem, we wanted to use the pulsin command to moniter our hall effect senors, but as it turns out, pulsin isnt supported. Sigh.. what to do. Any one have suggestions? am i going about this the wrong way? please respond
thanks
J.D.
Jedediah Wilson
Unread 08-02-2003, 01:45
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Originally posted by PyroPhin
you would have to team them.. would be a programinig nightmare to get two different motors to go the same speed on each side of the bot
~Pyro
Actually, it isnt that hard. Look at 60. Relatively simple drive, worked great with independently powered wheels.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 09-02-2003, 20:56
mav's Avatar
mav mav is offline
mav is an unknown quantity at this point
Send a message via AIM to mav
drills
our team is using just the two drill motors and we can get across the field in about 6 seconds but we still have a ton of power
Unread 09-02-2003, 22:05
Marc P. Marc P. is offline
I fix stuff.
AKA: βetamarc
Marc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond reputeMarc P. has a reputation beyond repute
Send a message via AIM to Marc P.
I like this year's drills much more than previous years, they do feel almost as smooth as the atwoods (for driving) and are very backdrivable as well. Given good traction, they can also be very very pushy/powerful, and are extremely responsive (from what i've seen driving our chasis around).
Unread 10-02-2003, 01:07
activemx's Avatar
activemx activemx is offline
A M X
AKA: Akshay Dodeja
activemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of light
Send a message via AIM to activemx Send a message via Yahoo to activemx
its all about the gearing, this year were using 2 chips(atwood) and drills. We having been using this combo from last year and they have worked extremely well if geared correctly. This year we had to redesign our gear box because they chaged the motors and our gearing is simple and comes out to be 11:1 from the chips to the drills. we havent really given it a shot on the the carpet yet. Thouhg its working well.
2005 - Present - FIRST Volunteer(Inspector, Ref, Judge)
2000-2004 MVRT 115
Unread 10-02-2003, 11:27
jmo8605's Avatar
jmo8605 jmo8605 is offline
jmo8605 is an unknown quantity at this point
Send a message via AIM to jmo8605
we are using the 2 drills and it takes us 5 secs. at 1/3 speed to get up the ramp, at full we will fly over it. Our robot also puts up a big fight in a pullin contest with a 200 lbs person on our team. Anyone jus locking into either low or high?
Jon
Unread 10-02-2003, 14:50
Thunder360 Thunder360 is offline
#0940 (Digital Demolition)
Thunder360 is on a distinguished road
I always liked the Atwoods, with proper gearing they can work wonders. The only reason I dont like the drills is that there tranny is mostly plastic. I dunno I just like simple parts that do simple tasks and work time after time. And the atwoods are very easy to mount, and they can take a huge beating and still work.
"Who needs Battle Bots, Ive got US FIRST!!!"
Unread 10-02-2003, 15:29
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
The Chiaphua is more powerful than the drill.
We accidently wired our combiner backwards and as soon as you put any substantial voltage to it, the chip would over power the drill. The breaker would trip every 1/2 second causing the robot to run in spurts...
Moral of the story: Never trust your sparkE's... I mean, the Chip is more powerful...
Complete Drill, Seat, and Window motors for trade archiver 2000 0 23-06-2002 22:16
Blowing drill motors archiver 2000 6 23-06-2002 21:58
what about the drill motors? Ken Leung Motors 2 26-06-2001 02:11
