Go to Post We're not behind, the rest of the world is ahead! Yeah. Thats it. - Curtis Williams [more]
Unread 11-02-2003, 11:10
Michael Long's Avatar
Michael Long Michael Long is offline
FRC #1024 (Kill-a-bytes)
Michael Long is on a distinguished road
Send a message via AIM to Michael Long Send a message via Yahoo to Michael Long
Question pressure switch
there is a set screw in the side of the pressure switch and ours leaks.... the screw was run in cross threaded and it ate up the hole.... if we just put some JB weld over the hold and plug it will it be OK? or do we have to order a new one?
Never Argue with an idiot...
They will drag you down to their level...
and beat you with experience...
Unread 11-02-2003, 11:21
George George is offline
#0060 (Bulldogs)
George is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to beholdGeorge is a splendid one to behold
Bullet
Order a new one!
Do Not USE!
Presser behind that "plug" can shoot it out like a Bullet!
watch the oz, the lbs take care of themselfs
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
pressure switch Antonio Pneumatics 10 31-01-2003 03:52
lost pressure switch Josh Hambright Pneumatics 0 29-01-2003 08:30
pressure switch piconysm Technical Discussion 5 14-02-2002 23:15
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
