Go to Post Karthik was never one to shy away from the spotlight (often to the chagrin of anyone within sight or earshot of him :p ). - Travis Hoffman [more]
Unread 14-02-2003, 12:00
GregC's Avatar
GregC GregC is offline
I Like Cheese.
AKA: GERG
#0384 (Sparky)
GregC is an unknown quantity at this point
Send a message via AIM to GregC
multi-bank programming problem
We have loaded the default program for the Multi-Bank programming. It tokenizes successfully, but when it it loaded into the RC, it gives a BASIC INIT ERROR and BASIC ERROR. We tried another computer and the INIT error went away, but the basic error still occured. We didn't modify the program.
Has anyone else had a problem with this?
Thanks.
-greg
cheese
Unread 14-02-2003, 12:20
Matt Reiland's Avatar
'The' drive behind the drive
We have not had any problems using the processor slots, if you don't get it soon maybe post it here or you can send it to me to look at
matthew.reiland@gm.com
Unread 14-02-2003, 14:25
Mr. Ivey's Avatar
Mr. Ivey Mr. Ivey is offline
Mark Ivey
AKA: Mark
Mr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of lightMr. Ivey is a glorious beacon of light
Send a message via AIM to Mr. Ivey
looking at through the parallax site, i found something about the multi bank code. and from the way i read it it seems you need to have a selector defining which band to select code from. as i had been saying in the meetings that we probably need to tell the chip which bank to read the code from. so if we bridge the pins to select the code and it works, i'm going to be all like "I TOLD YOU SO" and such.
~Mr. Ivey
When you tell a student not to do it, you shouldn't do it. Or else you will wind up with a 3/8" drill bit in your finger... Like I did...
Unread 14-02-2003, 16:13
Skabana159's Avatar
Skabana159 Skabana159 is offline
Robotics and Field Hockey
AKA: Jesse C. Owens
#0159 (Alpine Robotics)
Skabana159 is on a distinguished road
Send a message via AIM to Skabana159
Sorry, but could you explain what you mean by "multi-bank" program?
Usually a BASIC init error is caused by a problem in the serin, or the initialization constants (the ones that start with c_, and are set to 0 or 1). These are not caught in the tokenization, because everything is still syntactically correct, however there will be a strange or non-existant serial communication between the RC and the OI.
"What most people do not understand is that the Buddha, the Godhead, resides just as comfortably in gears and circuits as in hills and trees. To believe otherwise is to dilute the Godhead."
-Robert Pirsig, Zen and the Art of Motorcycle Maintenance
The problem with scouting... archiver 2001 10 23-06-2002 23:49
control system programming archiver 2000 17 23-06-2002 22:14
programming problem gthakore Programming 16 20-04-2002 12:21
Major problem with chipphua motors aka Scott White Motors 18 19-03-2002 19:44
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
