Go to Post "Nuclear" is pronounced "nu kli Er." It is NOT pronounced "nu kU ler." When you use this pronunciation, no matter how smart you may actually be, you sound like an illiterate dolt (are you listening, Mr. Bush?). - dlavery [more]
Unread 14-02-2003, 16:30
Fares Fares is offline
#1009 (Vikings)
Fares is an unknown quantity at this point
How do u hook up the digital input to the sensor's wires
ok , i think we are missing some kind of an adapter or something , because we don't know how to hook up our sensors to the digital input... is there some way of doing this ? it is very important because we want to test our programming and see if this thing works or not
plz help us out
thanks
Unread 14-02-2003, 16:41
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
you need a DB25 D-Sub connector. Solder cup.
you can find them at radioshack or one of those types of stores.
just solder your connections in there as described in the manual and you should be good to go.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
FotoPlasma FotoPlasma is offline
FotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond reputeFotoPlasma has a reputation beyond repute
Send a message via AIM to FotoPlasma
You need 25-pin D-Sub Solder Cup connectors, in order to connect bare wires to pins on the digital input port (well, there're other ways to do it, but this is the easiest, I think). You can find this type of connector at most electronics suplus stores. This year, as opposed to previous years, FIRST did not include these connectors in the kit, so you need to buy them yourself.
When you do get around to connecting switches to pins, make sure you follow the pinout on page 10 of the Full Size Robot Controller Reference Guide.
I just searched around a little, and found prices at $0.40, each.
Good luck.
I played hacky sack with Andy Baker.
2001-2004: Team 258, The Sea Dawgs
2005: Team 1693, The Robo Lobos
Robot Digital Input Mike Norton Technical Discussion 5 16-01-2003 14:31
