Go to Post Typed in "WaTeRgAmE" for the password and unfortunately it wasn't it. Bummer. - Kuhnahtt [more]
Unread 14-02-2003, 16:53
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Yaw rate sensor pin-out
I can't find the datasheet for the yaw sensor, can someone please tell me which is vdc, common, and output? Looking at the connector with the bolt holes down, the sticker on the left.
thanks,
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 14-02-2003, 16:55
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
i am currently looking for the exact same thing.
If i find it i'll post it.
i know that according to the manual from top to bottom its CBA
C=Analog Input ##
B=Ground
A=+5vdc
but i dont know what orientation that goes in.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 14-02-2003, 17:33
there is a datasheet that came with the sensor that has it on it.
Unread 14-02-2003, 17:39
Yes, and I lost it... I'm hopeing someone can tell me which pin is which.
Greg
Unread 14-02-2003, 17:59
sorry i cant get to a scanner otherwise i would scan it and post it.
Unread 14-02-2003, 18:08
Look, i know everything about it except which of the three pins go to what.
Fill in the blanks:
Pin 1: _____
Pin 2: Ground
Pin 3: ______
What are the blanks?
Unread 14-02-2003, 18:17
here is a pic.
Unread 14-02-2003, 18:18
Thanks a bunch!
Unread 18-02-2003, 00:07
I needed to know this last week, so I had one of our team look up my January posting on the subject, which I made with the data sheet in front of me.
Sure helps to use the CD search button.
Anyone know where to buy a spare yaw rate sensor? Jim Meyer Technical Discussion 11 30-03-2003 21:18
Yaw Rate Sensor to 90 degrees? Bruce C. Programming 4 11-02-2003 00:36
Yaw rate sensor (gyro for the layperson) Kris Verdeyen Rules/Strategy 4 14-01-2002 00:41
Yaw Rate Sensors dense Technical Discussion 4 10-01-2002 08:28
Yaw Rate Sensor ImmacGirl_03 Technical Discussion 2 10-12-2001 15:15
