Go to Post If people played without PDA's back when FIRST had this addiction to nigh-impossible-to-calculate-in-your-head multipliers, then we can play without PDA's now. - Ian Curtis [more]
Unread 17-02-2003, 12:00
RAWdealer59 RAWdealer59 is offline
#0059 (RamTech)
RAWdealer59 is an unknown quantity at this point
Pneumatics Questions
-Are we allowed to use three cylinders? Do we order them directly from BIMBA/PARKER, or from a local distributor (same brand)?
-Are we allowed to use more than two Clippard air tanks? (Hint, hint: In our case, four...)
Unread 17-02-2003, 12:10
RobDeCotiis RobDeCotiis is offline
FRC #1660
RobDeCotiis can only hope to improve
Send a message via AIM to RobDeCotiis
Re: Pneumatics Questions
you can use 3 cylinders. FIRST has provided one cyl in the kit of parts(the 8" stroke, 1.5" bore parker piston) and you can order 3 custom cylinders from bimba/parker using the order form provided in the manual. you're only allowed to use 2 clippard air tanks. i know, they're really small, but thats what FIRST gives us and lets us use. good luck
chanpionship questions????????? ivanslost Championship Event 1 13-02-2003 19:43
$3500 limit - Who does not have questions Raul Rules/Strategy 5 12-01-2003 11:31
Update 7 - Behind Schedule (or out of questions)? archiver 2000 2 23-06-2002 22:58
Pneumatics parts list questions archiver 2000 1 23-06-2002 22:48
2 questions Martin Rules/Strategy 5 12-01-2002 02:31
