Go to Post when I was a young whippersnapper, we didn't even HAVE Internet access at my high school in my podunk farmer town of Kinsman, OH! - Travis Hoffman [more]
Unread 17-02-2003, 13:16
AntmanIV AntmanIV is offline
#1089 (Team Mercury)
AntmanIV is an unknown quantity at this point
Send a message via AIM to AntmanIV
Exclamation Autonomous mode
Exactly how do they plan on turning the mode on? Thru the competition port or what? I was just wondering so I can finish my code.
Saru mo ki kara ochiru. --
Even monkeys fall from trees. or
Anyone can make a mistake.
What do bananas smell like?
Unread 17-02-2003, 13:30
Matt Reiland's Avatar
'The' drive behind the drive
Sorry to say this is about the 100th redundant question on this,
Yes it is through the competition pert same as disable of the robot
From Innovation First Programming Manual
Autonomous Mode
Bit 6 of the PB_mode byte (aliased as auton_mode below) indicates the status of the Autonomous Mode,
either Autonomous or Normal. This indicates when the robot must run on its own programming. When
in Autonomous Mode, all OI analog inputs are set to 127 and all OI switch inputs are set to 0 (zero).
Auton_mode is indicated by a blinking "Disabled" LED on the Operator Interface.
Auton_mode = 1 for Autonomous, 0 for Normal.
Autonomous Mode can be turned ON by setting the RC to Team 0 (zero) and power cycling the RC unit.
Please search the Forum before posting
Programming Autonomous mode Jared Stofflett Programming 3 11-11-2003 09:32
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
autonomous mode timer Don Programming 6 09-02-2003 22:16
autonomous mode Stephanie Programming 2 25-01-2003 19:57
autonomous mode? bigwalt Technical Discussion 1 21-01-2003 01:14
