Go to Post Roses are red/Violets are blue/I'll write a poem/Once build season's over. - Taylor [more]
Unread 17-02-2003, 19:31
rust710's Avatar
rust710 rust710 is offline
#0862 (Lightning Robotics)
rust710 is an unknown quantity at this point
Send a message via AIM to rust710
PWM port power
Does any one know how many amps can be safely pulled out of the PWM ports?
Andrew Radamis
Programmer on 862
info@lightingrobotics.com
Unread 18-02-2003, 00:00
Aren't they fused by one of the fuses around the rim ? Don't expect to use them for more than a few Gigawatts, tops.
The "Main" fuse, F1, passes 4.0 A, the Aux, F3, is 1.25 A, the other two are only 0.5 A
Unread 18-02-2003, 00:39
I seem to recal that the PWM ports supply 25ma each. A speed controller draws 10, so you can saftely run two of of the same pwm port. A servo draws 20, so you can't run two together, or in combination with a victor.
Unread 18-02-2003, 07:25
rust710's Avatar
Ok thanks. We wanted 5 volts to run something on our robot but 25 ma is not enough. Are we allowed to drop the voltage in custom circutry to supply us with the 5 volts at like 10 amps?
Andrew Radamis
Programmer on 862
Unread 18-02-2003, 09:00
Yes, you may regulate 12v from the battery to 5v for your custom circuit board (as long as your regulator comes from digikey or FAI, etc, etc)
What do you need to draw 10 amps for, though? Remember that you are only allowed to have the custom circuit board send data back to the robot controller. It can not control a motor directly or anything like that.
Unread 18-02-2003, 15:02
rust710's Avatar
The 10 amps is for a custom circuit but I don't think I am allowed to go in to anymore detail then that.
Andrew Radamis
Programmer on 862
Unread 18-02-2003, 20:33
Let's see...5 volts @ 10 amps...50 watts! Can anything be that important in a custom circuit board? Your are not going to find something simple to get you from 12 volts to 5 volts @10 amps. The biggest three terminal voltage regulator is only capable of a three or four amps, the standard 7805 is only an amp and a half. To get 5 volts regulated from the 12 volt supply you have to dump something like 70 watts into heat just to make the conversion. You can use the 7805 to drive a couple of power transistors in parallel but you would get 5.6 volts output.
Unread 19-02-2003, 07:50
rust710's Avatar
That is a lot of power I know but it doesn't have to be a persice voltage either. Really any voltage between 5 an 10 is good but it does pull a lot or amps.
Andrew Radamis
Programmer on 862
Unread 21-02-2003, 07:31
Don't do it directly from a PWM port !
rust;
In asking about PWM and Amps, you seem to indicate you want to vary a voltage for a HEAVY load.
The PWM outputs on the RC give little pulses every so often, NOT a continuous steady voltage. I haven't checked the timing since the 98 season, but they give an approx 1 ms pulse every, perhaps, 26 ms.
The way to achieve your end is to use a translator that will handle the current, and take the PWM signal and turn it into a voltage level. One such device is currently available to you : it comes from a company called Innovation First, in Texas. It is called a Victor 884. It gives square waves with a duty cycle from near zero to 100 % (not a square wave, just continuous 12 V). If your load can take 12 V with an average viltage of your choice (for instance a lamp, but not a portable radar-on-a-chip with a requirement for filtered 5 V dc)) then this is the way to do it. Current reportedly up to 40 amps.
Connect it, and in your program, limit the pwm signal to the maximum you want, and don't go to the other side of 127, if your load is polarity-sensitive.
Unread 21-02-2003, 07:44
rust710's Avatar
I forgot that a speed controller voltage probaly perfect to what I want but unfortunaly we have no more.
Really I care about voltage, between 5 and 10, constant at a voltage but other wise I don't care. My main problem is the amps. I have decided that I will not be able to get the power I need from the PWM ports so I am working on a alternate method of getting my power.
Andrew Radamis
Programmer on 862
Unread 21-02-2003, 13:56
Rust,
If you wish, you can contact me through private message and I will respond. Always glad to help.
pwm 13-15 wayne 05 Programming 2 04-10-2003 12:08
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
Fried program slots? Jeff Waegelin Programming 18 19-03-2003 18:08
power of globe motor with gear box? Ken Leung Motors 5 21-11-2001 13:43
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
