| My crate or yours? |
#31
Our bot (and some others) could get up enough speed on the ramp to jump over those wings. I don't know how well the landing would go though
#32
Yea, this was essentially what I was trying to lead you guys to. I was there las year, when MOE valiently attempted to hold his ground for 1:55 every match. This worked very well in the QP rounds, however, whenever we faced two good robots with a good about of torgue in the elims, our wings gave out on us. We had the file cards, like beaty, and we lifted up the goals for added traction to attach ourselves to the carpet. These worked very well, but when you make yourself that rigid, all the force is on that wing, and you will bend. Thats just my $.02
#33
Bah, our robot has so much tourqe this year, two bots pushing it will make it slide, or both bots on one arm will cause it to rotate. Or in our case we just go under the bar and ruin your bins
#34
Either Way
Either Way, I hope your strategy works for you and I look forward to meeting you guys at Nationals. Good Luck.
#35
Another great bot by the Technocats (it's spelled with a 'c' right?
). We should have a great time battling with you at the top of the ramp at the Midwest Regional.Please try to keep this thread on topic. If you want to talk about how powerful your robot is, start a new thread. This thread is about the Technokats robot. Mike |
#36
Pretty
(hey mike!)
I just hope you don't have what i think you have at the ends of those arms! (don't want to mention IT just quite yet, cause if IT 's not what i think it is, you could put IT there quite easyly and then EVERY ONE is screwed) Looks good! P.S. if you think i can't back my words up, i care not! |
#37
If you could cause the technokats robot to turn would it contact both sides of the ramp then violate the rules? I can't tell from the picture if that would happen. I'm willing to bet an experinced team like the kats would have thought of this allready. just somthing that poped into my head as I rwas reading the thread. Also to move the robot spin the bot have one team limbo the bar and come up behind them pushing from the back right and the second team pushes on the front left.
Nick |
#38
I'm hearing lots of things fly around this thread.
Frictionless pad - just so you know, there are several wheels available for purchase that give MUCH more traction of the HDPE than the carpet of mesh, and that traction is very nice Spinging a KOH bot - that'ld be hard, especialy when ur talking about veteran teams like the KATS Two v One pushing matches - look at beaty from last year, i remember one time when they had Kingman(undoubtedly the 2nd strongest pusher at nationals) and another team pushing full force against them, and beaty kept on moving basicly unfaised I've noticed people saying that you could life the KATS arms - that asumes several things, proper positioning of both robots to be one, I really doubt the KATS r just gona sit there and let u pick their arms up without a fight Suction Cups slide - maybe you haven't been informed, but there are some suction cups out there that are completly immovable, as far as you know the KATS have one on each arm Alot of times I see people who underestimate other teams and over estimate their own(I've seen this on my team ALOT) because they feel that they've spent so much time on their robot and it just isn't easy to think that you put so much time into something and someone else could be better. I think that this is what is happeneing to alot of people regarding the KATS. They are a veteran team with all sorts of tricks, so just sit back, relax, and keep an eye out on their regional showings. |
#39
I'm not sure how many teams actually do tests to figure the COF on different surfaces but I can give you some rough figures. On carpet some wheels have a COF of >1.5. I haven't tested or scene anything about the mesh but I think thats more dependent on tread than material. The HDPE is the most surprising, for some reason people think its this SUPER SLIPPERY surface when in fact its NOT. There are some materials that have a COF of >3.0 on it. Yes that was >3.0. So if the Kats or anyone else uses that stuff there not gonna move easily. If you doubt those numbers feel free to IM me.
It may just be an illusion but in the pics theres a small shadow under the central treads. It could be possible that they don't just drop there barriers but use them as jacks in order to give them a greater moment. |
#40
Re: Re: Yet another way
a) Start using the pictures online to get an idea of what is going to go on, make some base strategies, and then refine them when you see the robots in action or b) Go into the competition completely blind and trying to formulate strategies on the fly, not having anything prepared at all You see, with a little thought and some planning, strategizing now can help in the long run. And, is it hurting anyone? |
#41
You can see a little chunk it of (the blue stuff) under the grinder and drill press. http://www.chiefdelphi.com/pics/bin/...38dscf1803.jpg |
#42
Re: Re: Re: Yet another way
I'm part of stratage too Fluck, but the problem isn't you totaly trusting another team's pics, but going into a competition blindly not having a prep. Even if they have a secret weapon, you still know about 50% of what the bot can do. That's more than seeing it at the regional for the first time and having to do create a stratage based on little or no info.
#44
You can't make strategies by pictures alone, like I said in the previous post, the pictures are a basis, but they can't be used for main strategy. Strategy is a complex thing, you have to rely mostly on accurate scouting information and your own viewing opinions over what a picture shows. A picture tells a thousand words... yeah right. |
#45
You can decide on stratagies and other things by pictures. I can tell by your pics what we can do against you. I know it's not 110% accurate, but it's still more than you have anyway. |
| How much planning goes into your robot? | Jnadke | General Forum | 41 | 29-01-2006 21:29 |
| Rules on making spare parts fyi | DougHogg | General Forum | 0 | 02-04-2003 16:18 |
| Image Discuss: TechnoKat Robot 2003 - 2 | CD47-Bot | Robot Showcase | 6 | 27-02-2003 14:44 |
| WASH Palm scouting at the Championship | Mike Soukup | Scouting | 2 | 19-04-2002 15:14 |
| about how Drive Train push the robot... shouldn't the force accelerate the robot? | Ken Leung | Technical Discussion | 12 | 26-11-2001 09:39 |
