Go to Post I may be a little slow responding, I'm shoveling snow. - Mark McLeod [more]
Unread 19-02-2003, 04:34
AlbertW's Avatar
AlbertW AlbertW is offline
harker robotics :. 1072
AKA: Aonic
#1072 (Harker Robotics)
AlbertW is on a distinguished road
Send a message via AIM to AlbertW
Team 1072 (Harker Robotics Team)'s bot: Tork
This is our first year doing FIRST, and we're really proud that our bot works
It lifts boxes, stacks, and even traps people against walls!
http://sovereign.alnora.com/Tork/Tork.html
pic captions:
1: Tork on top of our makeshift ramp
2: Tork with boxes going down our makeshift ramp
3: our president trapped between a robot and a hard place
4: our faculty advisor in the background, with our driver inside the bot
5: some of our team with some of Saratoga High's team at their test ramp.
We were the first seeded first-year team at a first-year FIRST regional.
Unread 19-02-2003, 04:44
Alex1072 Alex1072 is offline
AKA: Alex
#1072 (Harker Robotics Team)
Alex1072 is an unknown quantity at this point
Send a message via AIM to Alex1072 Send a message via Yahoo to Alex1072
7 boxes high too=p
Unread 19-02-2003, 04:48
Katy's Avatar
Katy Katy is offline
Quis custodiet ipsos custodes?
Katy has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond repute
Send a message via AIM to Katy Send a message via MSN to Katy
*laughs* now there is something good to hear...
how fast can you stack seven?
Unread 19-02-2003, 04:54
AKA: Alex
Not very fast, but our strategy does not rely on stacking anyways.
Unread 19-02-2003, 04:57
AlbertW's Avatar
AKA: Aonic
one of these days, i wanna just sneak up on vivek and grab him with the robot...
wait. did i just say "sneak" and "robot" in the same sentence?
i must be high.
Unread 19-02-2003, 05:12
Katy's Avatar
what is you strategy?
Unread 19-02-2003, 05:16
AKA: Alex
you'll have to wait and see, but you could probably guess it...
Unread 19-02-2003, 06:53
Gadget470's Avatar
Gadget470 Gadget470 is offline
A Fire Outside
AKA: Brandon Joerges
no team (Alpha Omega)
Gadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the roughGadget470 is a jewel in the rough
Send a message via ICQ to Gadget470 Send a message via AIM to Gadget470
I like your method for changing orientation of the box(s)
As a veteran of FIRST, I must say, protect those cables in back. They will get hit with something, at their mounting point, when you least want it too, with the worst possible results.
You have a lot of weight you can work with, even if you are at 130lbs. If you have a drill press, put some symmetric holes in those side plates with a decent size hole saw. If that's 1/8" aluminum I can forsee about 5-7lbs you can drill out of those plates.
You look like you may have a decent CoG, so if you do drill out those plates, add weight at the bottom. But by all means, Protect those mounting points for the cables holding your stacker system.
Unread 19-02-2003, 13:19
AlbertW's Avatar
AKA: Aonic
we actually spent alot of time screwing with the CoG, not cause it was top-heavy, but cause it kept tipping backwards. you want us to protect the cable going up to the pulley? or the pneumatics tubing?
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
"Fixing" matches Shawn60 General Forum 158 18-03-2003 18:41
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
More 'Best' Robots (a well thought list) archiver 2000 2 23-06-2002 23:11
Disqualifications archiver 1999 13 23-06-2002 21:53
