Go to Post Look, it's only August. You got approximately 6 months to enjoy your life until season starts. Enjoy it while it lasts... - Arefin Bari [more]
Unread 12-01-2002, 08:32
Scott358 Scott358 is offline
Engineer/Mentor
AKA: Scott5736
FRC #5736 (Kingsmen)
Scott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really nice
Turning
As stated a few times, but is worth stating again, turning at a decent speed while holding the goal (and while having decent traction against being pushed sidways) is the real design challenge.
The wonder wheels (wheel with side rollers offering side motion as well as the wheels rolling) worked pretty well last year for some, but this leaves you very vunerable to being pushed sideways.
It will be interesting to see what people come up with.
Scott358
Unread 12-01-2002, 10:00
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
You need to think outside the box.
Turning if done right is very very easy. we can turn now with all three goal.
the fun part will be pulling other robots and still pull all three goals.
Watch the KSC in March 7-9
Unread 17-01-2002, 14:39
Andrew Dahl's Avatar
Andrew Dahl Andrew Dahl is offline
#0497 (Orange Crush)
Andrew Dahl is an unknown quantity at this point
coeff of friction
by using the above numbers-
the coeff of friction (for hard rubber vs carpet) for the goals on the carpet to be used in the comp
it is
Force of friction=mu * normal force
181= mu * 35 (assuming the max needed to move goal)
mu=35/181
mu (or the coeff of friction)=.19337
This sounds about right for the material in question
dahl
team 497
Unread 17-01-2002, 19:19
ggoldman's Avatar
ggoldman ggoldman is offline
FRC #0401
ggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud ofggoldman has much to be proud of
Send a message via AIM to ggoldman
That equation doen not seem accurate
You put the weight down..not the force pushing down
Te acutal force on the casters is as follows
181 pounds = 82.1 Kilograms
so 82.1*9.8m/s^2 = 804.58 Newtons of force total
Now... to find the coefficient of friction...
Friction = Mu*Mass*Gravity
or in this case ----> Mu(804.58)
so in order to move this goal...
You plug in the following
Force of Robots Push or Pull - MU(804.58) = 82.1* Acceleration
Now...to fin dthe minmum force needed to move the goal...
You set acceleration to zero...
So you get... Force of Robots Push or Pull - Mu(804.68) = 0
Force of Ropbots Push or Pull = Mu(804.68)
Force of Robots Push or Pull / 804.68 = MU
There you go...just plug in the force from your robot and you should find mu.
I need to check some notes..but there might be a better way...
And remember Its in Metric
G.Goldman
Unread 17-01-2002, 20:09
foursixnine foursixnine is offline
#0469 (Las Guerrillas)
foursixnine is an unknown quantity at this point
Send a message via AIM to foursixnine
we usda s spring scale designed for bows and got somewhere around 28-30 lbs of force to get it moving when all 8 casters were pointing sideways.
FIRST and Success: A Question of Definition Madison General Forum 70 27-11-2002 08:42
Small balls in 2001 competition archiver 2001 10 24-06-2002 03:59
Curie Division Robots information... (not complete) archiver 2001 3 24-06-2002 03:13
Team #237 2001 Robot - "Nineteen foot six" archiver 2001 13 24-06-2002 00:59
Just curious, how many robots could shoot or toss balls into the goal? Alan Ing General Forum 7 13-05-2002 19:09
