Go to Post The minibot horse is dead. Stop trying to beat it. Glue is too cheap. - Taylor [more]
Unread 26-02-2003, 23:44
CD47-Bot CD47-Bot is offline
FRC #0047 (Chief Delphi)
CD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond reputeCD47-Bot has a reputation beyond repute
pic: Team 870 Suction Cups
Unread 26-02-2003, 23:51
UlTiMaTeP UlTiMaTeP is offline
UlTiMaTeP will become famous soon enoughUlTiMaTeP will become famous soon enough
Our first ideas were to use out riggers and have 4 suction cups about that size or a little bit bigger, but after some testing we found out you could put 130 lb of suction cups if you wanted and they would do absolutely nothing. When you have a bot that weighs 130 pounds crash into you at 12 FPS your bot is gonna move thats a given, no matter how many suction cups you have.
Hows my searching? Call 1-800-Green-Dots
Unread 26-02-2003, 23:58
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
wow...those things are humongous.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 27-02-2003, 00:02
sevisehda's Avatar
sevisehda sevisehda is offline
sevisehda is an unknown quantity at this point
Send a message via AIM to sevisehda
Suction cups are kinda sketchy in my view. First they are only meant to resist force trying to pull them away from a surface. Second they work best on smooth surfaces. They don't resist nearly the same amount of force laterally. The amount of grip there gonna provide on a gouged surface is nothing compared to a good high COF >2 material.
Saying that 130lbs at 10+ ft per second is alot of bot for anything to stop. Just think of all those walls people have dented with a rampaging bot. At this point I'd put my money on a bot that has an inclined surface such as 229 and swampthing.
Watch this vid to see what I mean about the incline of 229.
http://www.clarkson.edu/~usfirst/our...d/WingTest.avi
Unread 27-02-2003, 00:14
Gope Gope is offline
#0016 (Bomb Squad)
Gope is on a distinguished road
It would seem to me that you have done little to no research on suctioncups. The right one can be incredibly strong and there are even some that can resist a lateral force better than an upward pulling force.
College and its wonders. First year and alot of other FIRSTs.
Unread 27-02-2003, 00:33
SlamminSammy's Avatar
SlamminSammy SlamminSammy is offline
SlamminSammy is on a distinguished road
Send a message via AIM to SlamminSammy
Bingo! Which is why I designed an L-shaped bumper system that dampened horizontal forces and then converted them to vertical forces. Therefore, before you could even start pushing the robot across the HDPE one would have to pull up the suction cups--a difficult task.
I personally thought my system was ingenious, but my team wouldn't even try it--possibly because it's never been tried before. I think this bumper system would make suction cups an invaluable resource.
Is this just my superiority complex speaking or was I on to something? (It's ok to be brutal )
The opinions stated above are not necessarily those expressed by the FIRST Robotics Program, its participating teams, or any other individual or organization.
Unread 27-02-2003, 06:40
sevisehda's Avatar
If your speaking of an L shaped bumper that pivoted in the bend its been done in the past. Except it was used to lift the agressing bot an inch or so off the ground so it would loose traction while the L bumper equipped bot would gain some.
I still don't see how your going to get suction if theres a gouge in the HDPE.
Unread 27-02-2003, 08:45
Katie Reynolds Katie Reynolds is offline
no team (NEW Apple Corps)
Katie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond reputeKatie Reynolds has a reputation beyond repute
Send a message via AIM to Katie Reynolds Send a message via Yahoo to Katie Reynolds
The possibility of gouges on the surface of the HDPE is the reason we didn't use suction cups. We found that even a fairly tiny scratch would weaken the suction so much that even I could pull the cups off with no problem (and I'm pretty weak! ) We tried a number of different things ... everything from gouges in the surface, to little scratches. We used plain ol' suction cups, and we used suction cups with a vacuum. The bottom line: No matter how tiny the scratch/gouge/mark/irregularity on the surface is, the hold of the suction cup will be weakened considerably.
Anyway, your bot looks great guys. Good luck!
- Katie
Team #93 - NEW Apple Corps
Student - 2001-2004
Team #857 - Superior Roboworks
Mentor - 2006-2009
Unread 27-02-2003, 10:24
f22flyboy's Avatar
f22flyboy f22flyboy is offline
Distributor of Mayhem
#0540 (Rhythmic Disturbance)
f22flyboy will become famous soon enoughf22flyboy will become famous soon enough
In defense of suction cups:
Suction cups that mechanically create a vacuum are actually pretty good at handling lateral force. They are the kind that are used for moving large panes of glass. One suction cup independently definitely won't stop 130lbs at 10 fps, but multiple ones, well placed, and backed up with good drive system, can probably stop all but the most powerful (and determined) bot.
edit- the way we tested this - a 160 student did pullups hanging on to 2 suction cups attached to a vertical pane of glass. Probably not the smartest thing, but it proves that they will hold lateral force. Also, multiple suction cups spaced out will minimize the chance that a large scratch will mess them up.
Godwin Robotics Association- Rhythmic Disturbance
Team 540 Forums
FIRST Look... FIRST Shot... FIRST Kill.
Unread 27-02-2003, 10:34
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
A 220 pound student on our team did pullups on two 4.5" di mechanical suction cups stuck to an enamel painted door jam. Also, I stuck one to the top of my washing machine and pushed it sideways as hard as I could and it would not budge. I even hit it with a hammer too and it didn't really move. There's a lot of science behind suction cups.
Unread 27-02-2003, 10:42
f22flyboy's Avatar
you have the same ones we do... good thing you aren't coming to our regionals
Team 540 Forums
Unread 27-02-2003, 11:55
Spikey's Avatar
Spikey Spikey is offline
Its NOT a Camera
AKA: College Advisor
FRC #0293 (SPIKE)
Spikey is just really niceSpikey is just really niceSpikey is just really niceSpikey is just really nice
We tested a vaccum cup on our robot and it was crazy, we had 4 people pushing the robot and it barely moved!! With two vaccum cups its gonna be really hard to move someone.
We did no use the vaccum cup because of weight but we have two smaller cups that work really well as long as we clean them before a match.
It's not a bug it's a feature!
"No, you may not drill holes in the air tanks to lighten them." -FIRST Q&A Repsonse to a question about lightening air tanks.
I'm the Not a Camera Kid at the New Jersey Regional But Not This Year, I am at Syracuse University Class of 2009
Uncrowned Champions of the 2005 Philadelphia Regional
SPIKE X NJ Xerox Creativity Award. Chesapeake Regional CHAMPIONS, and Motorola Quality Award
2006 Semi-Finalist at NJ Regional & Semi-Finalist at Chesapeake Regional, winners of the 2006 Xerox Creativity Award, and Judges Award
"Looks like SPIKE is doing its Batman thing again, that team looked like it was going to score, but SPIKE was not going to allow that to happen" -Play by play call at the Chesapeake Regional
Unread 27-02-2003, 12:07
Matt Reiland's Avatar
'The' drive behind the drive
I hope that teams out there won't be coating the botton of their suction cups with gels or fluids to try to get a better seal, that would get a pretty quick DQ in IMHO.
Unread 27-02-2003, 13:06
Steven Carmain Steven Carmain is offline
Bit Twiddler
FRC #2832
Steven Carmain will become famous soon enough
Whats on the pink wheels? There is no really good pics of it.
2017 - Team 2832 Mentor
2016 - Team 6013 Mentor
2002-05 - Team 45 Software/Electrical
A robot is like a campfire: it takes a while to bulid it, and then everyone surounds it!
A world without standards is chaos. A world with standards is chaos.
Unread 27-02-2003, 15:08
Rook's Avatar
Rook Rook is offline
#0267 (The Demolition Squad)
Rook is an unknown quantity at this point
If a team puts the thought into suction cups, they could be effective. I think many teams probably grabbed a plunger from the bathroom, slammed it down onto the HDPE, and then after watching it easily slide across the top, wrote off suction as an unworkable idea.
My team's fear of suction cups is the unpredictable nature of how much the HDPE will get scractched. We're pretty sure it's going to have some deep gauges from things like omniwheels, robots falling over, totes falling over, flailing arms, etc.
Aaahhhhh! The atmosphere! Aaaahhhh!
(Things you might hear a meteor say.)
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
pic: Team 870 Wiring Nightmare CD47-Bot Robot Showcase 15 02-03-2003 21:46
The 2003 Index of team's post about their robot... Ken Leung Robot Showcase 4 28-02-2003 00:18
pic: Team 870 Front Drive Train CD47-Bot Robot Showcase 4 27-02-2003 15:23
pic: Team 870 Rear Drive Train CD47-Bot Robot Showcase 2 27-02-2003 00:22
