Go to Post That's not duct tape as adhesive, it's duct tape as decoration! :p - Don Knight [more]
Unread 12-03-2003, 13:26
DougHogg DougHogg is offline
Robot-A-Holic
FRC #0980 (The ThunderBots)
DougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud ofDougHogg has much to be proud of
How to access other Digital inputs on OI?
Hi,
I would like to be able to add some digital inputs to the operator interface. I gather there are 2 bytes of digital inputs available. Right now we have 4 joy sticks attached to the 4 ports. That gives us 8 switches, which should use only 1 byte (8 bits), right? If so, what is the best way to connect more on-off switch digital inputs to the operator interface so they can be read using the remaining 8 bits available for digital input?
Thanks in advance for any help you can give me.
FIRST Team 980, The ThunderBots
2002: S. California Rookie All Stars
2004: S. California: Regional Champion,
Championship Event: Galileo 2nd seed,
IRI: Competition Winner, Cal Games: Competition Winner
2005: Arizona: 1st seed
Silicon Valley: Regional Champion (Thanks Teams 254 and 22)
S. California: Regional Runners Up (Thanks Teams 22 and 968)
Unread 12-03-2003, 13:45
Doug,
I f you check the OI docs from Innovation First you will find a discussion and drawing about using multiple joysticks. If you look carefully, you will note that the only way to get at the other inputs is to build an interface with joystick "D" connectors so that you can break out the digital lines separate from the analog. You then add another connector to pick up the digital inputs and pass them through to the OI. It easier to describe than accomplish, whew! Be careful for as you will notice, many inputs are duplicated on the four ports.
Unread 12-03-2003, 13:57
FRC Key Volunteer Trainer
AKA: CrazyNate
Here's a little something I worked up for my team...ignore the comments on the side, as they were specific to our control program, but this setup allows for all of the buttons and analog axes on the joysticks to still function, while breaking out the LEDs and digital inputs for use...
Nate Smith
nsmith@smythsoft.com
Serial Port and Custom Circuit Ryan Meador Programming 40 06-02-2003 11:34
Joystick Y-Cables Jeff Waegelin Programming 3 05-02-2003 12:37
Digital inputs, bandwith, errors? Micah Brodsky Programming 7 20-01-2003 16:08
Analog vs Digital inputs? f22flyboy Programming 8 08-11-2002 22:18
making speed controller digital CharlieWilken Electrical 4 01-03-2002 20:15
