Go to Post Has anyone else figured out a way to slip robotics into any conversation possible? Salespeople, nurse, dentist, pizza delivery guy... they all hear about it... It's gotten to the point where telemarketers will no longer call me, I have to call them... poor telemarketers... - MissInformation [more]
Thread Tools Rating: Thread Rating: 3 votes, 4.33 average. Display Modes
Unread 17-01-2002, 10:28
Jason Rudolph Jason Rudolph is offline
Alumni of 168
Jason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud ofJason Rudolph has much to be proud of
Send a message via AIM to Jason Rudolph
Thumbs up Game Simulator
I was just checking out the FIRST web site , and I found that they have put up this game simulator...
http://www.usfirst.org/robotics/2002/first_2002.swf
Unread 17-01-2002, 10:50
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
If you haven't seen it yet, it's in the White Paper for download (WIN, Flash, & MAC).
Unread 17-01-2002, 11:18
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Thumbs up
Just saw it myself. It is really great.
Hats off to team 217 for a great tool.
If anyone from 217 is out there listening, I have a few small (okay not so small...) improvements:
There should be a central ball queue.
Balls should be able to go to and from the queue to the following places:
Out of bounds
Each human station (10 balls at reset)
Each side of the field (20 balls at reset)
Each robot
Each goal
This would make it a 2 step process to get balls off the ground and in a robot and from a robot to a goal, but it would make all the features of the game doable -- at present, robots do not have balls, balls in human stations are not usable, etc.
Robots should able to "attach" to goals afterwhich moving one moves both. This is probably pretty tricky to do since there is a lot of geometery required and currently the robots and goals do not rotate. This feature would be nice but is not really a huge deal if it is too hard to do.
If you took the "attach" feature to extremes you may be able to attach two or more robots to eachother. You may let robots attach to ball locations so that a single click would take a ball from one place and put it in another (without going through the queue). Another example would be that if a robot & a goal were attached, one click would let balls go directly to/from the robot from/to the goal.
Finally, it don't recall if it displays the qualifying points as well as the match score, but it would be nice if it did that as well. (I suppose it does, but I was not looking at the time).
Bottom line, it is a VERY cool and useful tool. I hope they make it better.
Joe J.
From the central ball queue, balls should be able to
Unread 17-01-2002, 11:37
Alumni of 168
You can use the balls in the human player station, you just have to move the goals close to the human player station. I had problems with this at first too.
Unread 17-01-2002, 14:25
Joe Matt's Avatar
There sould be a thing where you can move your bot over to the end zone and pick up the balls in your team area. You sould also be able to clamp on to balls/goals in order to move them and mabey use the keyboard to move the bots around and make a game out of it, with AI for the opposing bots. But a VERY good tool none the less for rookie teams and vets working on stratage...
Unread 17-01-2002, 17:42
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Exclamation
The only change needed to make it a good simulator for strategy purposes is a tether feature to allow bots to be in zones 1 and 5. other than that, it is really good.
Zan Hecht
Unread 17-01-2002, 22:41
Tom Fairchild's Avatar
Tom Fairchild Tom Fairchild is offline
Nice Guy
Tom Fairchild will become famous soon enoughTom Fairchild will become famous soon enough
Send a message via AIM to Tom Fairchild
Now who would need that?????
~Tom Fairchild~, who can't think of anyone who'd have a legal non-entangling extension.
Unread 18-01-2002, 22:24
ahecht's Avatar
'Luzer'
AKA: Zan
We've actually come up with four legal extensions (two self deploying and two deployed by the bot), and are trying to decide which to use.
Zan Hecht
Unread 26-01-2002, 20:29
Edward Debler's Avatar
Edward Debler Edward Debler is offline
FRC #0217 (ThunderChickens)
Edward Debler has a spectacular aura aboutEdward Debler has a spectacular aura about
Post Regarding Game Simulator Comments
Regarding Game Simulator comments:
The 2002 FIRST game simulator as designed was intended to duplicate the movement of robots and goals to various zones on the playing field to give teams a "feel" for the steps they might take during a match. An example of this is, the orange balls can only be added to a goal if it is placed within reasonable proximity to the player station. Once that goal is moved fully out of zone 1 or 5, only the (nearest) yellow balls can again be added to it. Since the most probable scenario for balls to be scored is to have the goal somewhere near a ball location, that is the way the simulator was designed. Moving and controlling balls into and out of robots (that would in reality only hold a few balls) would add considerably more complexity to scoring.
Latching & Rotating:
Although Brian Debler considered robot latching to goals (or other robots), after many hours of development, it proved to be a very difficult task. He also considered rotation of the robots with/without goals attached (or rotating the robots about the goals) and found that the trigonometry involved was immense. Therefore these tasks were not included in the final simulator.
In any case, latching and rotation are not essential to operating the game (simulator). I emphasis the word (simulator) since that is exactly what it was designed to be. It is not an interactive game like something Nintendo might produce. The main objective of the simulator was to provide a visual medium that teams could easily use to assist with developing their game strategy as well as use during a match to track instantaneous match and qualifying scores. Judging by the number of hits on the Chief Delphi website (2136 as of this moment), I believe it has accomplished that objective.
Tether (or whatever):
There have been so many questions, comments and responses (to and from FIRST) that they all seem to be contradictory. I don't even want to go there in responding to any of them. In any case creating a method for the game simulator to account for scoring a robot in two zones would probably not be too difficult however, without firm direction from FIRST this late in the competition, I don't believe it would be that useful.
Simulator Development:
I would point out that Brian Debler worked more than 30 hours in less than 4 days (in his spare time) to solely develop the simulator so it could be available to all teams as soon as possible after the initial kick-off. He also of course accomplished this for no fee.
If you believe a more elaborate (realistic) game simulator would be of great benefit to FIRST teams in the future, then we should urge FIRST to fund development of a game simulator that would be available as part of the game kit and/or available to teams immediately after the 2003 kick-off. Of course, this would mean that FIRST would need to have the simulator development project started about 4-6 weeks before the 2003 kick-off.
I welcome any comments and suggestions regarding the development of a future game simulator for 2003.
Ed Debler
Team 217 ThunderChickens
Phone: 586-979-2205
email: edebler@comcast.net
Unread 27-01-2002, 11:33
Hubicki Hubicki is offline
#0007 (Team Firestorm)
Hubicki is an unknown quantity at this point
Thumbs up
Excellent job on the simulator. Your designers did a great service to all of the teams by taking the immense amount of time to create it. Only compliments were made from here at team 007. We can't thank you enough for this invaluable tool.
~Hubicki~
Unread 28-01-2002, 23:18
Lance Lance is offline
#0016 (Bomb Squad)
Lance is an unknown quantity at this point
Send a message via ICQ to Lance
Smile
Very Nice! This is a very useful (simulator) to calculate both score and qualifying score. We appreciate your hard work and time spent creating this model and we hope everyone finds it in time
Team # 016 (Baxter Bomb Squad)
Lance
Unread 30-01-2002, 01:21
Wetzel's Avatar
Wetzel Wetzel is offline
DC Robotics
FRC #2914 (Tiger Pride)
Wetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond reputeWetzel has a reputation beyond repute
Send a message via AIM to Wetzel
[b]
The only change needed to make it a good simulator for strategy purposes is a tether feature to allow bots to be in zones 1 and 5. other than that, it is really good.[b]
*waves hand*
We do! We do!
Or at least, we its working now...
Viva Olancho!
Unread 20-02-2002, 10:53
jeremy562 jeremy562 is offline
Engineer
#0562 (SPARK 562)
jeremy562 is an unknown quantity at this point
Send a message via AIM to jeremy562
Simpler scoring calculator
http://users.110.net/~jeremyw/score2002.html
This is a simple scoring calculator that I put together a while ago. Not as fancy as the other one (that's beautiful) but it works and might be more feasible for use at competition.
SPARK 562: Students Pursuing Applied Robotics Knowledge
2006 BAE Granite State Regional: Finalists with 319 and 176
2006 BAE Granite State Regional: Winners of Motorola Quality Award
2004 BAE Granite State Regional: 7th Seed
2004 Mayhem on the Merrimack Champions! Thanks, 61 and 1289!
Unread 07-03-2002, 02:52
ahecht's Avatar
'Luzer'
AKA: Zan
Well, check out our high-tech game simulator! It is entirely customizable and user friendly, as well as object oriented.
Okay, so maybe it is a magnetic whiteboard and some magnets, but it works!
Zan Hecht
Unread 07-03-2002, 03:17
Wetzel's Avatar
DC Robotics
Re: Simpler scoring calculator
It dosn't seem to include the ability for one robot to be in two endzones, unless I am using it it wrong....
Viva Olancho!
2002 game prediction contest!!! Ken Leung Rumor Mill 41 31-12-2007 18:18
What changes to this year's game...? DougHogg General Forum 16 20-04-2003 15:35
"Rigging" the game vs playing the game strategically - what's the difference? ColleenShaver Rules/Strategy 13 15-01-2003 10:33
Ok, so YOU design the 2003 game... dlavery General Forum 157 07-01-2003 23:55
Visual Game Simulator techknights General Forum 8 22-01-2002 19:43
