Go to Post Remember FIRST is "For Inspiration" of all students. It is a little tough to inspire students you won't allow in. - pafwl [more]
Unread 18-03-2003, 12:49
serious problem- robot controller resets if jarred!
EDIT: DID SOME MORE TESTING IN OUR LAB - THE PROBLEM WE HAD IS NOT DUE TO THE BREAKERS RESETTING THE ROBOT CONTROLLER -
SEE MY POST ON PAGE TWO THAT BEGINS WITH THE LINE:
"OK I did some more testing in my lab."
the subject line is a little misleading. The 20A breakers open when jarred causing the robot cotroller to lose power for an instant, and reset!
At the buckeye regional team 578 observed, in two matches, our robot restarted automode halfway through the 15 second period - both times after the robot was smacked.
We discovered the 20A and 30A circuit breakers open for an instant when jarred. You can try this for yourself - put a continiuty meter across a 20A breaker, then flick it with your finger, or tap it on the table - the circuit will open briefly.
These breakers are not defective, its a characteristic of the way they work - Bimetal strips that act as springs, and bend (pop) the other way when too much current heats them up.
This is what causes it to open on impact - it is esentailly a switch held closed with a small spring. When the impact force overcome the pressure of the 'spring' the breaker opens. The breakers look like a fat pizza box. We took one apart - the switch opens and closes in the same direction as if you were opening a pizza box.
What this means is, the robot controller power can be interrupted if the robot is hit, hits a wall, bounces hard on the ramp... when the power is interruped like this the controller resets, and if it happens in the 1st fifteen seconds, your auton mode code starts over from the beginning (we tested it - the controller does reset).
We emailed FIRST about this, and recommended all teams be allowed to use a 20A fuse (like the ones in the spikes) in the fusebox for the robot controller power. Its ok if your motors and other devices glitch for an instant when hit, so only the robot controller needs a fuse instead of a breaker.
if your bot is smacked at any point during the 2 minutes, and it resets, it will cost you several seconds of dead time, as the controller restarts and renegotiates the communication link - its more serious during auton mode because the automode sequence of events you programmed your bot to follow will start over from the beginning.
if FIRST wont let us use fuses instead of the breakers for the robot controller circuit, the one thing you can do is make sure your fuse panel is oriented, screwed to a vertical surface in the bot, so the 'pizza box' shape is flat in the robot. This will lessen the susceptability to impacts in the X and Y planes, and put it on the Z plane - so if your bot is dropped (gets lots of air) then the breaker will be most likely to open, and less likely to open from a front/back or side impact.
another solution is to shock mount your breaker panel.
The fuses that are in the spikes are 20Amp (and they are supplied by FIRST). The fuse is simply a strip of metal that melts when too much currrent flow (it gets hot). The fuse cannot reset. There is no logical reason why you should not be able to use a fuse for the robot controller. There is no condition in which the controller should be drawing more than 20 amps (unless you have loose metal bounceing around inside your robot.
I have not heard anything back from FIRST yet on the Q&A section in the robot rules section - they have not even posted the question yet. If you dont see a respose from FIRST on the Q&A forum then raise the issue yourself with the judges/inspectors at your next event - advocate a fuse be allowed in that circuit (for all teams) - or at least orient your fuze panel so the breakers are flat.
If you are trying to achieve king of the hill in the last seconds of your final match for the regional trophy, and you are smacked at the top of the ramp, breaker opens and your controller resets for several seconds
it will be all over.
-Ken Wittlief sparkie engineer team 578 'Blue Lightning'
NASA/Gleason/Fairport - see you in Toronto!
Unread 18-03-2003, 12:59
edited to fix subject line
Unread 18-03-2003, 13:16
Josh Hambright's Avatar
Josh Hambright Josh Hambright is offline
{Error Processing Custom Title}
AKA: oneangrydwarf/jtosh
no team (old school gangsta)
Josh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond reputeJosh Hambright has a reputation beyond repute
Send a message via AIM to Josh Hambright
i also heard that a team at the buckeye regional found that if you jarr the modem enough you can actualy cause a basic init error and cause your robot to reset.
So it seems that maybe our problems of robots dying last year from the 120 amp breaker getting jarred could have been an even bigger problem then previously expected.
Former 461 Student/Mentor. Former 1272 and 1018 Mentor. Team 1555 Super-Fan.
Science and Engineering Can Open New Doors. --S.E.C.O.N.D.--
Co-Founder IndianaFIRST
Share your FIRST photos on Flickr!
Unread 18-03-2003, 14:30
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Ken,
Are you sure the resets are due to the circuit breaker opening? I'm not surprised if the breakers open momentarily, but have you been able to run your robot into a wall or something and see it happen? There is a really monsterous capacitor inside the robot controller and I'd be a little surprised if it couldn't overcome a very momentary loss of power like that.
Our team has had some really solid hits to the walls both from autonomous and driver controlled and we've never seen resets due to shock like you describe. By any chance to these resets only happen on the ramp? If so it could be the static discharge that's getting you. There's another thread that Al from our team started about this problem. We also discovered that the reset pin on the RC is exposed through the programming port and is highly susceptible to noise. On our robot controller, merely having a serial cable plugged into that port and having it unconnected on the other side will put the RC into a constant reset state.
Unread 18-03-2003, 14:56
The two matches where we saw our bot restart auton mode from the beginning, one the L/R switch we have on our bot was suppose to be on L, and the student set it to 'KILL' - :c)
the bot backed up like its suppose to, turned right 45° instead of left, then slammed full speed into the railing right in front of the judges table, then the bot reset, backed up again, turned 45° right again and slammed into the opponets operator station, leaving a 2 foot scratch in the plexiglass (Buckeye match 57)
we never made it to the ramp.
The other match was similar - we were pushed backwards down the ramp then hit by another bot at the bottom, and our auton sequence restarted.
We have nothing connected to our program or tether connectors during a match. In fact, i would not be surprized if this is the real cause of bots resetting at the top of the ramp (they get jarred when they land hard or hit the stack, lip, other bot...)
Other teams have reported seeing bots get hit, then go dead (light goes off) for a few seconds, then restarting.
And yes, I did test this with a robot controller on the lab bench with a 20A breaker in series with the 12V supply - you flick the breaker with your finger, or tap it on the bench (not that hard either) and the robot controller resets, and renegotiates the radio link (takes a few seconds).
This is a definate problem with using the breakers to protect the robot controller (instead of a fuse).
BTW - I have taken one of this years robot controllers apart (we sheared a fuse - now using it for a spare on old bots) I dont recall seeing any really big caps in there.
Unread 18-03-2003, 15:00
also - if you have your breakers oriented flat, or sideways, they are less suseptable to a front impact. We have our breakers vertical, narrow edge front to back - so they would be most suspectable to a side impact - but our bot still reset when it hit the railing head on.
Unread 18-03-2003, 15:18
Andy A. Andy A. is offline
Getting old
FRC #0095
There is (or at least should be) a capacitor in the RC that smooths out the power supply just for this reason. Momentary drops in power are pretty normal, and shouldn't cause a full reset.
It sounds like either this RC doesn't have one or it just isn't working right.
Try this: Attach a capacitor (+12 volt and a couple hundred micro farads) across the power terminals of the RC. Power up and test it again. The capacitor should supply power for a second or two if the power flicks out and the RC will never know the difference.
Do you have another RC you can test?
-Andy A.
Unread 18-03-2003, 15:27
Steven Carmain Steven Carmain is offline
Bit Twiddler
FRC #2832
Steven Carmain will become famous soon enough
I like this idea, but isn't this illegal for competion. I see this for troubleshooting purposes only.
2017 - Team 2832 Mentor
2016 - Team 6013 Mentor
2002-05 - Team 45 Software/Electrical
A robot is like a campfire: it takes a while to bulid it, and then everyone surounds it!
A world without standards is chaos. A world with standards is chaos.
Unread 18-03-2003, 15:32
The RC I tested on the bench is not the one that was in our bot when it reset, so I have bench tested one, and 'field tested' another.
I dont know why there would be a large electrolytic cap in the robot controller - Its powered by a battery, which would have very little ripple - but I will open our spare one up again and look for large caps.
The RC takes quite a bit of power - it powers the radio modem, any sensors you have on the same breaker, any servos connected to the PWM outputs - so some robot configurations might drop out faster than others.
But even still, caps are intended to smooth out noise and ripple on the power supply, not to hold it up during power interuption.
If anyone has the ability, please verify my results in your lab. I believe this is potentially a serious problem for all teams - having your auton mode restart, or loosing the link for several seconds during a match can result in your bot being damaged in a collision, or loosing the match in the last few seconds.
Unread 18-03-2003, 15:33
adding a cap would be against the rules - I have formally asked FIRST to allow us to use a fuse instead of the breaker in this one circuit (fits in the fuse box the same as the breaker)
no response from them yet.
Unread 18-03-2003, 16:02
seanwitte seanwitte is offline
None #0116
seanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant futureseanwitte has a brilliant future
Send a message via AIM to seanwitte
onboard regulator
There has to be a cap in the controller to filter out noise from the motors. The secondary effect would be to smooth out momentary power interruptions. There has to be some kind of regulator in there to step the supply voltage down to 5V, I bet theres at least a diode and a filter cap on the supply-side.
I know this is a dumb question, but did you check the leads on the battery? We had a loose screw on a battery terminal that was occasionally causing it to reset. Or maybe a connector on the breaker panel is loose? We saw that come up as well. If tapping the breaker is causing the reset then maybe one of the leads is loose or not seated in the connector all the way.
Unread 18-03-2003, 16:07
you can take a 20 or 30 A breaker, put alligator or push on test leads on it, and connect it to an OHM meter (that beeps for continuity)
and tap it on a hard surface, the breaker will open. Maybe I will take a JPEG of the one we cut open so you can see whats inside the breaker
there is a big contact slug on a fairly thin sprung piece of metal.
The breakers would make an excellent impact sensor :c)
Unread 18-03-2003, 17:55
Software Engineer
Rookie Year: 1995
Re: onboard regulator
Yup, we have a controller apart here (it's not this year's, but I doubt they've changed much) and it has two good size caps near the power connector: a 100uF and a 1000uF.
I recommend you watch the voltage readout on your OI sometime when you take your robot from a standing still position to full speed, or worse, full reverse to full forward. The voltage will drop by quite a bit. On our 4WD drive robot last year we would frequently see short dropouts to down near 8v when the match began, since our drivers were holding the sticks full forward. Those caps are in there to supply power when the battery voltage drops too low like that. Various parts of the RC use an 8v regulator which requires some voltage higher than 8 to maintain a steady output. Look at the PDF I'm attaching - the first graph is a plot of our battery voltage over 1 match at the Great Lakes Regional last year. The graphs following are current measurements from each of our motors. If it weren't for the above mentioned caps the RC would reset pretty much all the time.
In my mind, a very short power interruption from a jolt is the same thing as noise. Noise causes the voltage to quickly drop and come back, just like bumping the breaker. What's the difference?
Unread 18-03-2003, 19:06
Alexander McGee's Avatar
Alexander McGee Alexander McGee is offline
Hoonigan
AKA: Alexander S. McGee
no team (no team)
Alexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond reputeAlexander McGee has a reputation beyond repute
Send a message via AIM to Alexander McGee Send a message via Yahoo to Alexander McGee
Unhappy Uhh
this is not good. However, i think that your auto mode is tost if you hit anything anyways, right??
-Alexander S. McGee
Intellectual Property Attorney, Mechanical Engineer, Gear-head
Unread 18-03-2003, 19:09
I am not surprised that tapping a breaker on the table would show a momentary open circuit. But that is not a fair or scientific test. If your breaker was mounted near a hard surface and a robot maneuver would cause the breaker to crash into that surface, then I think that would be a valid test. As Dave described above, there are large capacitors in the controller to at least smooth out the voltage fluctuations supplied to the RC. We suspect that Innovation First has made an improvement on that in the new RC for this year as it appears to be less susceptible than even last year's. However there are limitations on how sensitive this can be based on your electrical design. Frequently, high current connections pass through high resistance contacts that move when subjected to shock. This movement results in noise and power interruptions to an already low power circuit. I would more suspect a bad crimp, loose connector or voltage sag caused by high current loads than a breaker.
As to the large capacitors filtering out noise from the motors... large capacitors of the type we are talking about, usually have to high an ESR to be effective at high frequencies. A more reliable filter can be made from small ceramic capacitors, RF chokes, etc. Unfortunately, FIRST has always considered the addition of capacitors to anything outside of the custom circuit board to be illegal. I have heard a report that one regional allowed this addition but have not heard anything from FIRST yet. Expect to be asked to remove it if you are inspected with it in.
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
RC resets itself when robot tries to move cheesinglee Electrical 28 04-07-2003 21:59
Controlling a FIRST robot with a Lego RCX Controller? archiver 2001 5 24-06-2002 04:19
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
