Go to Post it is actually more important to understand and be able to clearly state the question than it is to know the answers. - GeeTwo [more]
Unread 23-03-2003, 18:41
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
gear shifting
On our bot we use the drills as our primary motors. Unfortunately we have had problems shifting them with servos because they don't go all the way into one position or another consistently. Has anyone run into this? Does anyone know a better way besides using pnuematics? Any ideas are appreciated!
Thanks
JSK
Unread 23-03-2003, 18:45
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
I think pneumatics would be awfully hard to use and not break the collar on the motor. When you shift them and they dont go all the way, as soon as you drive a bit, the gears should mesh and the collar should fully move into either the hi or low gear position, at least they do in our design.
Cory
2001-2004: Team 100
2006-Present: Team 254
Unread 23-03-2003, 18:48
BSEE, MSEE, JD
AKA: employed
no no no....we use the servo motors to switch as of right now....we have determined that we won't use pnuematics that is why I said other than pnuematics.
Unread 23-03-2003, 18:55
REVving up for a new season
FRC #2848 (All-sparks)
how are your servos connected to the transmissions.....one fix that I have encountered is that the servos arn't powerful enough to shift so the fix is to extend the arm and use leverage to help...... also with servos you have to come to a complete stop before shifting.....if you want me to get more specific in how to use leverage please e-mail me tarbell@comcast.net
Unread 23-03-2003, 20:07
K. Skontrianos's Avatar
K. Skontrianos K. Skontrianos is offline
FRC #0102 (Dexterous Gearheads)
K. Skontrianos is an unknown quantity at this point
We've used pneumatics to shift for the last 3 years without breaking a single collar.....ever.
www.team102.com
2000 National Finalists
2003 J&J Mid-Atlantic Regional Winners
2003 BattleCry Best Autonomous
Unread 23-03-2003, 20:14
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
How are you attaching the servo to the shifter? I would get a better idea if you tell me how.
Unread 23-03-2003, 21:59
BSEE, MSEE, JD
AKA: employed
we have the drills mounted in the plastic mounts then over top of them upside down we have the servos mounted on aluminum brackets. The servos then push the collars back and forth as needed....hopefully that clears it up a little bit. Any ideas
Unread 24-03-2003, 17:10
Adam Y.'s Avatar
Adam Y.
no team (?????)
And you say you are not getting enough throw with the servo's directly mounted on the gear box? Why not try using a mechanical linkage to increase the throw? They are designed to be used with servos and are used to for linear movement. Im sorry if Im not that much help.
Unread 24-03-2003, 17:20
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Try some of these. They will all fit right on the output of the servo and have multiple mounting locations for linkage. You should be able to get most of them at any quality hobby store.
http://www2.towerhobbies.com/cgi-bin...rn&FVPROFIL=++
Unread 24-03-2003, 17:32
jon jon is offline
jon has a spectacular aura aboutjon has a spectacular aura aboutjon has a spectacular aura about
We use servos to switch gears too... and it was working very nicely, until our servos burninated, and we were stuck in low gear during competition. That hurt us a lot.
Unread 24-03-2003, 18:39
Mike8519's Avatar
Mike8519 Mike8519 is offline
FRC #0303 (TEST Team)
Mike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really nice
hey jon did Trogdor happen to in the near vicinity to do the burninating
Unread 24-03-2003, 19:56
BSEE, MSEE, JD
AKA: employed
oops I forgot to mention that we have a tiny linkage in between the servo and the collar....sry. We have a servo wheel horn with a metal linkage from that to the collar to be exact as possible.
Unread 26-03-2003, 21:11
PMGRACER's Avatar
PMGRACER PMGRACER is offline
AKA: PAUL GIANNOSA
PMGRACER is on a distinguished road
We had a horrible time shifting with servos last year. One of the problems is that the "slider" in the trans that moves between the planetary sections pivots on 2 horizontal pins. There is quite a bit of clearance between the housing and the slider, which allows the slider to rock on the shifter pins and not mesh into high or lows squarely. You would be better off to build a custum housing and shift fork that you can space the pins 120 degrees apart. That's what we did this year. I have a few photos posted in the Gallery. This has been a very reliable system. As far as shifting method, pneumatic or a servo would work consistantly. If you are familiar with R/C car suspensions, you can use the little ball joints and Tie-rod screws to build a sweet linkage for the servo method.
Racing is an incurable addiction!!
Unread 26-03-2003, 21:31
scuba_sm's Avatar
scuba_sm scuba_sm is offline
Deriva-what?
#0862 (Lightning)
Team Role: Student
scuba_sm is on a distinguished road
Send a message via AIM to scuba_sm
Quite frankly, I haven't been to impressed with the servos. They have a mechanical freedom of almost 360 degrees, but our programer said he could only get 180 degrees of movement. That was a bit of a bummer, however, if anybody's got any information to the contrary, it would be much apreciated.
S cubed
President 862 Lightning Robotics
My Aresenal for this year:
AK-38 "Lobster"
"Big Daddy Riveter"
Pneumatic grinder
Oh the joys of industrial equipment.....
Unread 26-03-2003, 21:49
Cory's Avatar
AKA: Cory McBride
hmmm ive played with the servos before, and they looked like they had a rotation of around 270*ish.
Cory
2001-2004: Team 100
Thunder Chicken CCT Simon G Motors 4 03-01-2003 13:18
low gear vs high gear archiver 2000 1 23-06-2002 23:07
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
Drill motor gearBox question Dennis Hughes Motors 4 11-10-2001 07:11
